Does anyone know transmission capacity
Old Jun 18, 2004 | 06:05 PM
BOB-O's Avatar
I just changed the cV boots and had to drain the tranny. The Chilton book says the capacity for refilling is 15.5 pints. I put in two quqrts qnd it is full. Am I missing something, or did I misunderstand the book. Does anyone know the amount? Thanks for any help.
Old Jun 18, 2004 | 06:10 PM
DanNY's Avatar
Ad·min·is·tra·tor
hmm..you pulled the axle out and got a bath of ATF right?
15.5 pints is 7.75 quarts. basically it's a refill when it's being rebuilt or pulled apart.
drain and fill is about 3-4 (ball park).
if you didn't pull the drain plug then figure 2ish should be right. always check..there's a dipstick for a reason.
Old Jun 18, 2004 | 06:27 PM
BOB-O's Avatar
I used the dip stick, that's why I stopped. I drained the transmission, and pulled the axles, luckily, I had people in the ORG give me good advice. When I put it back together, it only took two quarts. That filled it just right on the dip stick. Does it retain a lot in the transmission when you use the drain plug? Do you have to take the pan off to fully drain it?
Old Jun 18, 2004 | 07:59 PM
DanNY's Avatar
Ad·min·is·tra·tor
did you check the ATF level when the car is running?
what pan?
Old Sep 18, 2005 | 08:49 PM
DanteGTS's Avatar
i got this form this site:
http://auto.consumerguide.com/Auto/U...ewreliability/
it said:
"Automatic transmission: If the transmission does not shift properly until warmed up, make sure it is filled only with Nissanmatic "C" transmission fluid. (all)"
I checked with the dealer for this soo called Nissanmatic "C" transmission fluid but they have no clue what it is. I use the dealer recommended transmission fliud and it does not shift properly until warmed up.... so what kind of tranny fluid do you guys recommend for a 89 transimisson?
Old Sep 18, 2005 | 08:56 PM
Greeny's Avatar
¯\(°_o)/¯
Just use Dextron/merconIII....They don't make Nissanmatic "C" transmission fluid anymore.....
Old Sep 18, 2005 | 09:03 PM
maxitech's Avatar
I use Valvoline High Mileage. It's pretty good.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
