Okay I Goofed (Craig Brace!) any other wire guru
Old Jun 23, 2004 | 07:12 AM
dkris42's Avatar
okay so i was trying the cruise control mod and well i put the end in the wrong part of the relay and now i have no cruise control switch at all. KNow if you dont know this, it is where you put 2 ends in a relay to over ride the relay...well your suppose to put it in the relay port 3 and 5 but i missed it and put it in the wrong one now i have no cruise control ligth on my stich so im assuming i have no cruise control.....what should i look for? what blown fuse or w/e should i look for? I didn't hear anything or anything light just won't work.
Old Jun 23, 2004 | 08:29 AM
«§»Craig B«§»'s Avatar
it's probably not a good idea to start adding wires across two terminals when you aren't completely sure of the wiring behind it
if you're lucky, you just blew a fuse. I think there is a page in the FAQs that has all the fuse descriptions on it - might be a useful thing to look at. Here's a hint - Nissan calls the cruise control ASCD (automatic speed control device)
Old Jun 23, 2004 | 08:56 AM
dkris42's Avatar
i knew what i was doing and i did it all right i just looked at the relay backwards....and crossed the wires. and thank you and yes i knew the ASCD
edit: there is no fuse portion that i could find.
Old Jun 23, 2004 | 11:29 AM
dkris42's Avatar
could I please get a little bit more help please.
Old Jun 23, 2004 | 12:13 PM
www.geocities.com/craigbrace
Old Jun 23, 2004 | 04:40 PM
dkris42's Avatar
OKay i drove it today and found out everything that didn't work.
abs light is on, cruise control switch nor cruise work,automatic a/c doesn't work,rear defrost, im not sure about the clock because that rearly works.
so if anyone has a clue what to do look for all the fuses looked fine.
Old Jun 23, 2004 | 05:28 PM
all those things are controlled by the same fuse, what a coincidence
sometimes you can't just look at a fuse and tell if its bad or not, you need to test it - either test continuity across the fuse or test voltage on both sides of the fuse when it should be on (ACC/ON/START/whichever type of fuse it is)
Old Jun 23, 2004 | 06:56 PM
dkris42's Avatar
lol.....yes it was controled by the radiator fan fuse on the inside of the car. I feel stupid lol. fuse tester didn't do anything. took each one out till i found the right one. Thanks for your always help and intteligence on everything electrical.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
