Bad engine mounts - Y pipe vibration
Old Jun 25, 2004 | 05:56 AM
Bill Doran's Avatar
I know the correct fix for Warpspeed Y pipe hitting sway bar causing vibrations at times is to replace the mounts, but I don't want to put any more money into car at this time. Any ghetto suggestions to cushion pipe and muffle noise?
Old Jun 25, 2004 | 07:41 AM
subs1000w's Avatar
pull the mount and fill them with 3m window weld
Old Jun 25, 2004 | 08:42 AM
-shock211-'s Avatar
get a strong metal pipe with a wheel attached, mount it to the oil pan. make sure the pipe is a 1/2" or so too tall. that way it will push up on the engine a bit to keep the mounts from sagging. you'll be the first 5 wheel max!!! :
j/k
try and find some used mounts at a wreckers to save money.
Matt93SE
Apr 8, 2018 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
FlaMark
25
Aug 28, 2015 10:15 AM
laparka66
Aug 6, 2015 09:36 AM
