VE engine pull..sorry no search
Old Jun 26, 2004 | 06:08 PM
Luv4DSC's Avatar
quick question I'm pulling the motor as of now (91 5spd) any tips and does the tranny have to be dropped 1st from the bottom or can it come out as an assembly?
Old Jun 26, 2004 | 06:14 PM
James92SE's Avatar
2 VE's are better than one!
You can pull the whole thing out as one unit from the top
Old Jun 26, 2004 | 06:43 PM
Matt93SE's Avatar
STFU n00b!
Uhhh, you can't pull the engine and tranny out from the top.. not enough room. If you don't separate them, you have to pull them out from the bottom.. It's not hard, just messy. jack the car up as high as you can, and you should have room.
Old Jun 26, 2004 | 06:44 PM
Luv4DSC's Avatar
thanks alot!
Old Jun 26, 2004 | 07:02 PM
James92SE's Avatar
How cant you? I did
Old Jun 26, 2004 | 08:30 PM
MrGone's Avatar
How cant you? I did
I thought so too, but didnt want to own Matt
well plus I had a second thought that maybe you pulled the tranny first and was too lazy to search for the pics, which could have resulted in my owning myself
Old Jun 26, 2004 | 09:41 PM
Jeff92se's Avatar
I'm needing a caw
You can pull both from the top but it's tight. But you aren't pulling a VE if you have a 91se. A VG might allow some more room. Thing is if it's tight, you end up banging on stuff to get it out.
If you jack up the car, you have to lift the front end really high. ie..maybe 3.5-4+ ft. And you have to drop the engine on some cardboard then slide it out. If you try to set the engine down on a dolly, you have to jack up the car even more.
Old Jun 27, 2004 | 04:22 PM
Golden Ice's Avatar
I used a skateboard when i dropped the bad tranny outta my first truck..and only had it up maybe 2 feet in the air..course, that was in a mid 80s GMC and it was ONLY the tranny..so..your results may very..an old creeper or skateboard or somthing should be short enough and strong enough for a motor and trans out of a max..
Old Jun 27, 2004 | 04:28 PM
internetautomar's Avatar
mod or sell?
it's not like a fiero?
Where you undo 4 bolts and the whole shebang sits on the ground while you lift the car off of it?
Old Jun 27, 2004 | 09:05 PM
MaDMaX024's Avatar
How cant you? I did
+1 for me
+1 for another org member..
Old Jun 27, 2004 | 09:36 PM
Matt93SE's Avatar
STFU n00b!
Tried to go that way with a VG auto and it wouldn't fit. the total length was 1" wider than the frame rails.. of ocurse that's still with all the other crap in the engine bay. had I stripped it completely down, I might have been able to get it out. You also don't need the car 3.5 ft in the air either. a VE is 27.5" tall, which is taller than a VG. so there's less than 2.5 ft up that you need to get it out.
Old Jun 27, 2004 | 10:48 PM
James92SE's Avatar
Well, mine came out diagonally, to say the least
Old Jun 28, 2004 | 05:21 AM
Matt93SE's Avatar
STFU n00b!
yeah, it's easier to just jack up the car, put it on some tall jackstands, wrap some chains around the exhaust manifolds, then drop the engine. it's only.. umm 6 or 7 bolts holding the engine and crossmember in. then you've of course got the wiring up top and the exhaust, but that's the hardest part.
Old Jun 28, 2004 | 05:35 AM
DanNY's Avatar
Ad·min·is·tra·tor
it can be done Matt...i can show you.
you have to remove the crank pulley. the engine/tranny should be tilted. tranny should be lower. that should give you JUST enough room to pull the motor out w/ the tranny.
Old Jun 28, 2004 | 05:40 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
OWNAGE!!!! just used one this weekend to pull redmax's VQ, finally no more "drop the motor...readjust...lift"(repeat 3-4 times)
Old Jun 28, 2004 | 05:44 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes...very useful item.
Old Jun 28, 2004 | 07:12 AM
Jeff92se's Avatar
I'm needing a caw
I guess you don't have to lift it up that much if you remove the x-member. But then you have to drop it down on the oil pan.
Old Jun 28, 2004 | 08:04 AM
Luv4DSC's Avatar
it pulled out from the top just fine only thing in the way was the ac line, didn't have to drop and repeat anything just pull.I did take out the battery tray tho...helped out alot
Mar 12, 2020 12:06 AM
seesole
Sep 14, 2015 12:38 PM
adamgalazka
Sep 8, 2015 01:27 PM
minsbang
Sep 5, 2015 05:36 AM
