Valve above egr?
Old Jun 26, 2004 | 10:20 PM
Luv4DSC's Avatar
Valve above egr?
on the motor I'm putting in the valve is missing but mine has it so I swapped the housings and there is oil behind the butterfly plate that bolts to the intake, and the motor still in the car has no oil behind the plate. What does this mean? And what does this odd valve do, I've never seen somthing like this. Thanks (vg)
Old Jun 27, 2004 | 07:25 AM
Luv4DSC's Avatar
come on anybody? Need some help..it looks like some kind on speed sensor...its a 2 part deal one piece has 3 screws that screw onto the housing and the housing has 4 bolts holding it to the manifold, and the housing has a small butterfly in the middle
Old Jun 27, 2004 | 01:22 PM
GreenMaxVE's Avatar
I don't know what valve you are talking about. Perhaps you can post a picture so that we may see what you are talking about.
Old Jun 27, 2004 | 07:13 PM
Luv4DSC's Avatar
its the only thing directly above the egr (where it mounts to the intake) one inch above it, you look at the egr and you can't look at it without seeing what I'm talking about, it also has vaccum lines and electronic connections. Thanks with any possible help
Old Jun 27, 2004 | 10:03 PM
maximagxe90's Avatar
Hi,
show us on the picture what you are talking about
Old Jun 27, 2004 | 11:48 PM
Luv4DSC's Avatar
alrighty the hose on the air intake tube right before it clamps to the intake follow it to the round thing that bolts to a housing right above the egr. behind that housing there was oil what does this mean? my other had no oil there
Old Jun 28, 2004 | 05:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
it's idle control (AAC). the "butterfly" adjusts how much air gets in and around the valve. you also notice there 2 rubber collant hoses running to and from it. the valve/butterfly is temp dependent.
if there's oil behind it...it usually means you have a real dirty intake manifold and the motor didn't get PCV valve changed when it's needed.
slight bit of oily goo/carbon is ok. if there's a lot of oil in there you might want to look into the problem.
shilov
Feb 19, 2024 09:40 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 19, 2015 01:07 AM
