mix/match springs? plus bushing question
Old Jun 28, 2004 | 09:34 PM
93max's Avatar
what would happen if i put sprint in the front and susp. tech in the rears? some whack handling? and the control arm bushing, is there a sleeve on the inside and outside on the one that is towards the front?
Old Jun 29, 2004 | 05:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
usually companies design their springs to work as a set. not sure what would happen...but i'm going to guess that your handling might be off. one end might be softer than the other...etc.
Old Jun 29, 2004 | 07:31 AM
Golden Ice's Avatar
i forget which my uncle had put where, but when he had the car, he mixed and matched stock height springs and struts..The car handles fine, though it has some flaws around high speed turns because it was wrecked (almost totaled) a couple of years after they bought it..they bought it in '92, and in '94 it was like $120 short of being totaled..unless you know exactly what you're looking for, you'd never know it had ever been wrecked..it was hit in the right rear side..but anyway, you might have some trouble, but I'm not sure..just ignore everything I've said if you want..
Old Jun 29, 2004 | 11:15 AM
Matt93SE's Avatar
STFU n00b!
you need to pay attention to spring rates when you're doing stuff like that, but it's possible. I personally wouldn't mess with it though, simply because you don't know what kind of handling you're goign to get with the different spring rates. car may be undriveable, it may be perfect (I highly doubt it tho)
As for the bushing, there are sleeves on the inside and outside for the front one. about 3/16" of rubber between the bushing.. in this drawing, the black outer part is the control arm. blue is metal, and the hashed part is rubber.
Old Jun 29, 2004 | 12:36 PM
-shock211-'s Avatar
i wouldn't suggest mixing springs....but like people are saying, there's a chance that it could turn out okay.
if you plan to change the control arm bushings yourself....have fun!
you'll likely have to burn them out.
Old Jun 29, 2004 | 12:57 PM
dkris42's Avatar
so what woulod happen if you put 17 in the front and 18s or 19s in the rear?
with a uniform suspension
Old Jun 29, 2004 | 01:19 PM
Matt93SE's Avatar
STFU n00b!
you'd look like a ***.
Old Jun 29, 2004 | 02:04 PM
dkris42's Avatar
hehe sorry it just went and i had to ask
Old Jun 29, 2004 | 03:28 PM
internetautomar's Avatar
mod or sell?
you'd have a FWD car that looks like a bad RWD setup
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Stagnet04
Sep 13, 2015 09:32 PM
