checking a fuel injector
Old Jun 29, 2004 | 12:18 PM
n1_saxman's Avatar
Ever since my trip from Utah to Washingtonand back, my car has not run the same. I did a balance test on the cylinders today and when I pulled the spark plug wire off cylinder five's plug, it didn't seem to make any difference. I checked the spark and pulled the other plugs and they all seem the same. So is this a compression or injector problem??
~Ryan
Old Jun 29, 2004 | 12:32 PM
-shock211-'s Avatar
~Ryan
considering you have a vg30e....it's the injector causing the problem.
you need to test it with a multimeter and find out the resistance of that injector. it's supposed to read 14ohms iirc
Old Jun 29, 2004 | 12:45 PM
goon9's Avatar
where's a good deal on injectors?
Old Jun 29, 2004 | 12:58 PM
n1_saxman's Avatar
good question!! anyone help us out?
Old Jun 29, 2004 | 01:19 PM
goon9's Avatar
What do u mean by not running right? I think i was having an AAC adjustkment problem because of poor gas milege. And yes i changed my O2. which made a little change. Runs like crap still though.
Old Jun 29, 2004 | 01:51 PM
Mizeree_X's Avatar
Getting back to his roots
I have a spare set of VE injectors
Old Jun 29, 2004 | 02:24 PM
n1_saxman's Avatar
the motor is definitely missing a little. Before the trip when I would have the car in neutral, I could give the throttle a good jolt and she'd wind up, but now when I do that, it stumbles then winds up a bit. does that make sense? I can't tell of any power loss because I got spoiled down at sea level in Wahington and am now back up at 4500 feet in Orem.
Old Jun 29, 2004 | 02:42 PM
bkea's Avatar
injector problems
I had a similar problem with my 89. It was bad injector
connectors. I could make it happen by bending on the wires
leading to the connector and then make it stop by additional
movement. The problem went away after replacing two of
them, but has returned.
Old Jun 29, 2004 | 02:45 PM
bvtran's Avatar
94c Big Max
if yours is a vg, all you have to do is unplug each injectors and probe each connector. you should be getting anywhere between 10-14 ohms. if not, then it's dead. If yes and you're still getting problems, then you could be having clogged injector, compression problem, worn piston seals, etc.... Also, check the engine to see if there were any cracks, sometime too much advanced timing and constant usage of low octane grade gasoline could caused these problems. Me personally, I think 15 degree adv timing by factory default is a little high for nissan to tell us it's alright to use regular. Maybe 10 degree sounds better for that type of cheap booze.
Old Jun 29, 2004 | 03:33 PM
internetautomar's Avatar
mod or sell?
Won't help, 89-91 has a different connector
Old Jun 29, 2004 | 04:32 PM
broncoguy's Avatar
Injector...I'd almost guarantee it.
There's been a lot of discussion here about aftermarket vs. dealer parts, injectors included. They're damn expensive from the dealer, but they'll probably last longer. I bought one from Direct Auto (online) last year for $35.99 plus a $12 core. But, it is now leaking. Lifetime warranty, tho, but they'll probably make me send it in first- like that works.
Anyway, that's what I know about it. If anyone has any better places to get them, we're all ears (Internetautomart...??)
Old Jun 29, 2004 | 08:43 PM
n1_saxman's Avatar
what's the best injector cleaner/gas additive? or are they all the same?
Old Jun 29, 2004 | 08:44 PM
n1_saxman's Avatar
btw, no matter what octane fuel I put in, I still have a detonation problem. Could it be anything other than the timing (like a mixture problem)??
Old Jun 30, 2004 | 03:39 AM
mod or sell?
could be an injector leaking and causing the detonation, but that is fairly uncommon.
The new injectors from bosch are the same as the dealer ones.
They run about $100 ea. and as I've said before DON'T buy remans on the nissan injectors, they have a VERY high defect rate especially the 89-91 VG
Old Jun 30, 2004 | 08:46 AM
grody's Avatar
I've got a set of 6 VG injectors from a '92 that tested exactly 11.8 ohms each. I'd sell them to you on the rail, $125 + shipping.
Old Jun 30, 2004 | 12:12 PM
n1_saxman's Avatar
why are you selling them then?
Old Jun 30, 2004 | 12:20 PM
mod or sell?
Maybe cause 92 up and 91 down are different.
Old Jun 30, 2004 | 12:45 PM
grody's Avatar
Are they? They look identical to the ones off my '90.
Because they came with my new motor. I had a set that were also good in the old motor. I got them all cleaned up along with the TB, intake manifold, etc, before I got the new motor, so I used them. The crank on the old motor broke, right at the nose, so I lost the valves also.
Old Jun 30, 2004 | 01:10 PM
mod or sell?
oopsie, the VG got the change in 93.
The VE always had the newer connector.
Old Jun 30, 2004 | 03:13 PM
Luv4DSC's Avatar
I'm having very similar problems my 91 broke the crank at the snout and I dropped a 92 motor in and #6 injector as just peeing in the cylnder so I swapped the rail from the old motor now it mists but it loads at idel and gas fouls the plug while holding 173 on compression and has damn good spark
Maxboy23
55
May 1, 2025 06:09 PM
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
aminus21
Sep 12, 2015 04:53 PM
