Code 12 (MAFS) Need help! Matt? Jeff?
Old Jun 30, 2004 | 05:35 PM
Julio's Avatar
I was driving my car the other day, and it started running like crap. It barely ran. I had to use very partial throttle, and couldnt get high in the rpms at all. I checked my codes when I got home, and got code 12, which is the MAFS code. I checked all connections, and all were fine. At idle, vacuum would steadily drop from 20 to 15 in hg, then revs would go up and bring the vacuum back up. I disconnected the s-afc, and the vacuum problem went away, but still couldnt drive it, cause it ran the same way.
Next thing I did was disconnect the MAF all together. Car runs fine in "limp mode" until the 2400 rpm limiter is reached. I followed the FSM procedure fully twice for the code 12, and tried another MAFS, but of course it didnt make a difference (shouldnt have since the procedure went ok).
That made me think that the connections in the ecu harness were bad, so I checked them too, but they came out fine too.
Anyone have any suggestions? Matt or Jeff?
Old Jun 30, 2004 | 06:26 PM
Matt93SE's Avatar
STFU n00b!
sounds like you gots a big problem.
you've done everything I would do.. can't help much past that point over the 'net. good luck mang.
Old Jun 30, 2004 | 09:12 PM
jim90gxe's Avatar
Did you check maf cranking+idle voltage and continuity at the ecu harness? The FSM should show cranking and idle voltage.
Old Jun 30, 2004 | 09:17 PM
Jeff92se's Avatar
I'm needing a caw
Yup. Hard to say. You've done more than would have. Possibly a bad maf ground wire? You can try adding an external ground.
Old Jul 1, 2004 | 03:31 AM
internetautomar's Avatar
mod or sell?
Scope time!
Old Jul 1, 2004 | 06:03 AM
Julio's Avatar
Thats part of the fsm procedure, all voltages came out fine, and all wires had continuity
TallTom
57
Oct 14, 2025 05:16 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
