lightend flywheel ?
Old Jul 3, 2004 | 04:35 AM
corrupted's Avatar
lightend flywheel ?
ok im replacing my tranny today since one of the bolt that hold the pressure plate to the fly wheel broke and got shot into my case now i was wondering if i should have it lightend or not since it at the machine shop now i do tend to drive my max very very hard i would just get a aluminum flywheel but i need to get back on the road tonight so thats not an option at the moment any opinions on this would be great and very helpfull thanks in advance
Old Jul 3, 2004 | 05:13 AM
Matt93SE's Avatar
STFU n00b!
Sure... they can take out about 3lb of steel off the back.. but it won't do you much good overall, since the factory one is over 20lb. fidanza is 11lb.
Old Jul 3, 2004 | 07:55 AM
Ninty-two-se's Avatar
I'm thinking about getting a fidanza when my clutch goes... will this affect how the engine runs in the winter/ cold weather? Also if I get a lightened UDP along with the flywheel will it make the engine run differently/worse/ less reliable in the winter?
Old Jul 3, 2004 | 07:58 AM
Matt93SE's Avatar
STFU n00b!
Think about it for a minute... what does temperature have to do with the engine running properly using lighter components?
Old Jul 3, 2004 | 08:20 AM
todamax's Avatar
I started typing a sarcastic "if will **** up your car if you do that" response, but I just couln't post it.
Put the lightened components on, you will love them. It doesn't have an impact on relability.
The biggest question you have to ask, is if your car is worth a $300 for a flywheel + $100 for a UDP. That $400 that doesn't go toward things that are broken.
Old Jul 3, 2004 | 10:51 AM
Cliff Clavin's Avatar
Way out West
also, you might as well add around $250-300 for an ACT or Exedy stage 1 clutch. If you are going to do all that, might as well have the right clutch for that kind of performance.
I love my Fidanza/ACT set up. It is not really like stock (not as smooth), but it is definitely fun and worth it to me.
Old Jul 3, 2004 | 04:40 PM
Anything would be smoother than the clutch in it right now... I had a performance clutch... I think... or weird/broken clutch.. in my first maxima and all the action was at the bottom it was like an on-off switch and it made it hard to feather it when stopped on hills or starting out when not paying attention.. is this just the clutch I had or is that a common thing with the racing/performance clutches?
Old Jul 3, 2004 | 06:56 PM
Matt93SE's Avatar
STFU n00b!
sounds more like a crap install.. either it was a bad clutch or throwout bearing, or something was messed up in the hydraulic lines.
but a high performance clutch will be more like an on-off switch over a smooth engaging OEM-like clutch.
Old Jul 4, 2004 | 10:21 PM
bonzelite's Avatar
i recommend the fidanza flywheel mod. you will notice it. it is not one of those barely-felt mods. do upgrade the clutch, though. i got valeo stg 1.
don't bother resurfacing the oem flywheel.
Old Jul 5, 2004 | 05:31 AM
Will the flywheel and UDP affect reliability, engine life, or driveablility in a negative way? This car is my daily driver and I need it to get me to and from work and school everyday... Sorry for the dumb questions... I'm just that kind of person who needs it all spelled out... Thanks for your opinions
Old Jul 5, 2004 | 06:21 AM
internetautomar's Avatar
mod or sell?
well they will cause your cause mileage to go down in direct relation to the increased propensity of the right foot to go down faster/farther than prior to their install.
Old Jul 5, 2004 | 08:39 AM
bonzelite's Avatar
right. what he says ^^^.
that is about the only negative of it.
Old Jul 5, 2004 | 08:57 AM
icepick's Avatar
$100 for a UDP. were post link
Old Jul 5, 2004 | 09:18 AM
«§»Craig B«§»'s Avatar
THis aRe liNK tHEre :
www.rpmoutlet.com
Old Jul 5, 2004 | 09:37 AM
MrGone's Avatar
but you can still get more miles to the tank if you drove teh exact same on one car with a fidanza/udp and one car without the fidanza/udp.
Craig-
bawahahhhahhahaahahaa
Old Jul 5, 2004 | 04:19 PM
mod or sell?
My flywheel is cross-drilled
Old Jul 5, 2004 | 06:20 PM
MrGone's Avatar
My flexplate is cross-drilled
fixed.
Old Jul 5, 2004 | 06:31 PM
mod or sell?
Originally Posted by MrGone
fixed.
just wait I'm gonna slot it too
Old Jul 6, 2004 | 06:11 AM
icepick's Avatar
does that help any and are you seriuos
Old Jul 6, 2004 | 07:22 AM
mod or sell?
I've got an A/T it comes holey from the factory.
I don't think slots would help.
Old Jul 6, 2004 | 07:50 AM
bonzelite's Avatar
cross-drilled/slotted flywheel
they're pulling your leg, matey.
Old Jul 6, 2004 | 07:57 AM
icepick's Avatar
thats what i thought
Old Jul 6, 2004 | 07:58 AM
icepick's Avatar
does the asp under drive pully hellp alot and does any one know belt sizes link? or post plz?
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
