Testing Spark Plug Wires
Hi, I replaced my spark plugs in hope to stop engine from missing. Is still does it. Next thing I would like to check are the wires. I heard somewhere that you can check them with a multi meter is this true? How much resistence should there be on the stock wires? Thanks.
just make sure the wires are all within 1 ohm of each other
With the car running, unplug one wire at a time:
1) If the car runs worse, wire is okay
2) Runs the same, that wire might be bad.
Add: Stumbling could be a faulty egr or pvc valve also. Cracked dist cap would do it also.
@Jeff92se...
Would you unplug the wires in sequence, and would you unplug the wires from the distributor or from the engine? My car had the Bosch 7mm spark plug wires installed when I purchased it, so I'd like to find out if I should be looking to replace them or not. I'm sure it's about time for another major tune-up (just passed 200K about a week ago!) and will be searching for the NGK V-Power plugs again, unless there's something better out there for a VG.
Thanks!
peace2u
Thanks!
peace2u
if the car runs worse the wires could still be bad. even wires with very high resistance will still transmit some voltage to the plug and possibly light it off.
if it runs the same then you've only begun to start checking, but at least you know a cylinder to start with
At least you could track it down to the cylinder. Especially if it's stumbling while idling or neutral reving.
I'd unhook them at the plug
not quite jeff.
I just didn't want them to think they were completely eliminating a possible cause when they aren't
Originally Posted by 90Maxximus
I found the cylinder that is not firing. Its #4 but the spark its making it through as it arcs when it gets close to the intake. So.. Iam thinking fuel injector or valve
. What do you think?
. What do you think?MIKE
Is there a way I can check the fuel injector without a NOID light or anything else like that. Thanks for the replys.
MIKE
