Suspension Woes
Old Jul 9, 2004 | 01:51 PM
MaximaBalla's Avatar
Suspension Woes
Alright, so I just got the Max all done with lowering it. Haven't gotten pics up yet though cuz it's been raining. I got KYB GR2's with ST springs. The ride is great but only when the roads are dry. When I'm driving in the rain, the car goes everywhere and I have almost no control over the steering. If I go over a slick spot, the steering wheel jerks over that way. It's a b*tch to try and drive in the rain! I know I am for sure getting an alignment, but do you think that it is just out of alignment? Should I get a fstb too? Thanks in advance.
Old Jul 9, 2004 | 01:59 PM
goon9's Avatar
Your tires suck. lol, I have the same set up, and it's awesome in the rain.
Old Jul 9, 2004 | 02:04 PM
I've got stock rims with Michelin Pilot MXV4's with great tread on them.
Old Jul 9, 2004 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
Get it aligned. Does it pull one way while in the dry?
Old Jul 10, 2004 | 06:00 AM
Nope, drives great when it is dry.
Old Jul 10, 2004 | 06:25 PM
internetautomar's Avatar
mod or sell?
Definitely get it aligned.
and good tread does not neccesarily make a good tire.
My camaro's tires have like new tread depth but they ain't worth a ****!!
(of course they are also older than some members on here )
Old Jul 10, 2004 | 08:18 PM
HTPerformance's Avatar
some tires just arent good in the rain
Old Jul 11, 2004 | 05:49 PM
Maxininct's Avatar
I did my suspension this past winter myself and drove it home from friends house without alignment being done and i thought i was gonna crash. You DEFINATLEY need alignment when changing the ride hight of the car. When i seen the angles on the computer when getting alignment done at friends shop the meters were of the charts ( the wheels were way alignment) get the alignment done and u will be all set. =)
Old Jul 11, 2004 | 10:20 PM
Maxzilla91's Avatar
i think u prolly have worn out tires to begin with. but did u get a camber kit to adjust ur camber as well?
cuz' if u lower ur car ur wheels tends to be slanted whereas normally the wheels are perpendicular to the ground. if ur wheels are slanted inwards at the top that's called positive camber.(it might be other way round, someone correct if i'm wrong.)
so when ur wheels are slanted, u're only running more on the inside edge of ur tires depending on how much camber u have, and therefore, less contact between the tire and the ground.
u can fix that by getting a camber kit that corrects ur camber so that u have full contact between ur tires and the road surface, and therefore more traction. that's always a good thing right?
Old Jul 11, 2004 | 10:28 PM
Maxzilla91's Avatar
internetautomart, ptuning.com, autocarparts.com all carry camber kits for 3gen max.. so u can check those out...
Old Jul 11, 2004 | 10:47 PM
Maxzilla91's Avatar
Oopps.. didn't read all the posts so i didn't see that ur tires aren't so worn. sry..
but still, get the camber kit to have ur whole tire on the road.
and michelin makes good tires(hella expensive too).. but i have Yokohama H4S, it's doing awsome in both wet and dry..
Old Jul 12, 2004 | 08:19 PM
StRacer718's Avatar
I have the same camber problem since I have a lowered car. My wheels tuck in at the top so the inside thread on my tires always wear down. Its a real pain in the butt having to change tires every three months, maybe i'll look into the camber kit you guys are talking about.
Old Jul 20, 2004 | 04:49 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
man i was looking into lowering but if i need a camber kit too forget it too much work, i just wanted to pop in new springs and struts......and get it aligned....
Old Jul 20, 2004 | 04:59 PM
Brad92SE's Avatar
Just buy the eibach camber bolts from some place. I got mine from tire rack, they only cost like $20 for the pair, and you have to pull out the factory bolt that they replace anyways to change the struts.
Old Jul 20, 2004 | 05:15 PM
mod or sell?
MANY companies make alignment bolts. Don't even worry about them a good alignment shop will either have them on hand or be able to get some (only applies to the front)
Old Jul 20, 2004 | 06:21 PM
thumpyls's Avatar
ur tires must be bald the inside could be smooth and the middle and outter parts are threaded on the inside.i would get the kit to save money on tires and be able to drive in the rain
Old Jul 20, 2004 | 07:41 PM
Matt93SE's Avatar
STFU n00b!
Sure... but they try to charge you $75 PER BOLT..
just install them when you're installing the struts. it costs an extra $20 and takes ZERO additional time to install. put the springs on the car, drive them a couple hundred miles until the springs settle a bit, then go get it aligned.. tell them the bolts are already in it and to use them if needed to correct the alignment. done.
Old Jul 21, 2004 | 08:47 AM
mod or sell?
never had that problem,
But then again I've always been a wholesale account
Old Jul 31, 2004 | 04:16 PM
Alright guys, just got back from a vacation and had the car aligned while gone. When I got home, it was pooring down rain. It was prolly the only day in my life when I was actually glad it was raining! lol But, anyways, the guy told me that the car was wayyy out of alignment. Now, it rides sooo smooth on the road in the rain now. I'm soo happy that I got this done. And to everyone, trust me, I work at Discount Tires, I HAVE GOOD TIRES!! haha
Old Jul 31, 2004 | 07:46 PM
goon9's Avatar
...You can get discounted good tires?
Old Jul 31, 2004 | 09:27 PM
lophix's Avatar
felt i should share....
mine had the same symptoms as well. Stock. I changed springs, struts, sway bars and upgraded my tires (17s with over 90% tread, fresh, no irregular wear) still persisted. I then changed my balljoints and a control arm bushing and the problem subsided a whole lot. I'd attribute it to control arm bushings, possibly balljoints. Might as well get them changed since you've probably never done them.
Old Aug 1, 2004 | 08:56 AM
Yeah, I can get discounted good tires. The tires on my car right now were free!! lol
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
