Wheels smokin!!
Old Jul 9, 2004 | 06:21 PM
swowlinc's Avatar
1993 SE
Wheels smokin!!
This is the bad kind.! I was frolicking through the city at random high speeds today. Anyway after a while of this , I came to a light and noticed my brakes were smoking a little. So I took it easy on the way to a friends house and its been fine since but what do I need to do, just get better rotors and pads??
Old Jul 9, 2004 | 06:29 PM
Kikcaffine's Avatar
It shouldnt be a big deal, unless you sprayed water on the rotors, in that case ur plucked, and will need new rotors. My advise if your going to keep driving like that, get brembo cross drills and some ebc green stuff brake pads. Also get some wheels that have a larger opening like 5 spoke ones so air can flow over them. Finally just remember that though this is a sports car, its a 4 door sports car, so its got some extra heft!
Old Jul 9, 2004 | 08:21 PM
swowlinc's Avatar
1993 SE
Yeah, I had 2 extra passengers so it was probably too much for the stock brakes to stop all that weight at high speeds for long. I experienced brake-fade too.
Old Jul 10, 2004 | 06:32 AM
Matt93SE's Avatar
STFU n00b!
1. Brembo crossdrilled will only make the problem WORSE, not better. for performance uses, stay away from the crossdrilled rotors.
2. a Maxima is not a sports car. it's a four door sedan with a decent amount of power..
he is correct in that what you saw was your brakes overheating. if you're seeing fade on the street then you need to SLOW DOWN- especially with passengers. it's not only dangerous, but it's stupid.
Old Jul 10, 2004 | 05:06 PM
swowlinc's Avatar
1993 SE
Yes that would be stupid to drive around like that, as for me, I still want to know what I can do to improve my brakes. Thanks anyway
Old Jul 10, 2004 | 05:43 PM
goon9's Avatar
Matt ur saying that cross drilled rotors shouldn't be used for daily driving?
Old Jul 10, 2004 | 06:38 PM
thumpyls's Avatar
cross drilled rotors have less surface for u to brake on..they keep ur rotors cooler but when ur driving at such crazy speeds i would suggest some slooted with green stuff pads..if u like hauling a## then steel braid ur brake lines also
Old Jul 10, 2004 | 08:21 PM
Matt93SE's Avatar
STFU n00b!
I don't suggest crossdrilled rotors, period. on street-driven Maximas, they have a horrible tendency to crack--no matter how well designed they are.
I had a set of brembos with properly raduised/chamfered holes and they didn't even last 10k miles before cracking. many many other people have had these same problems. do some searching on it and you'll find tons of issues with them.
you'll notice a lot of places are selling dimpled rotors instead of crossdrilled. that's 95% of the reason why they're doing it.
Old Jul 10, 2004 | 08:45 PM
swowlinc's Avatar
1993 SE
So our best bet would be to keep the factory rotors and get better pads then. I maxxed out the max at 130-ish, I NEVER drive that fast but I just couldnt resist the open road (usually theres always cars blocking the way of progress over 100) plus I was kinda following 2 bikes w/ chicks on the back showing buttocks and they were bawlin' boy!
Old Jul 12, 2004 | 09:38 PM
StRacer718's Avatar
If you have some extra cash to invest you could get a big brake kit and upgrade to a bigger rotor and bigger calipers. With the bigger setup stopping a Maxima won't at high speeds shouldn't be a problem.
Old Jul 13, 2004 | 06:16 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes...get the Z32 brakes.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
