17 " Wheels
Old Apr 3, 2001 | 01:32 PM
Chitwista's Avatar
I have just ordered a new set of 17" Chrome wheels for my Maxima.. The question that I had is this?? What would be a good tire size to match with 17 " wheels on a 1989 Max, I am looking to fill the wheel well as best a possible but still have a nice looking tire.. any suggestions would be a great help.. Thank you..
Check out my Maxima here at >>
http://members.cardomain.com/chitwista
Let me know what you think..
The wheels that I ordered are the same style and finish as the ones I have in the pics, but instead of 15" they are 17"
Old Apr 3, 2001 | 01:49 PM
maxmizd27's Avatar
Plus-sizing 101
17" wheel should take a 45 series tire in about a 215 width (depending on the wheel width) ex 215/45-17. For each inch increase in wheel diameter the sidewall aspect ratio number decreases a factor of 10. Stock diameter was 15" with a 65 series sidewall becomes a 17" 45 series sidewall. 16" would be a 55 series as I have. Tire Rack's web site is a good source of info for this kind of stuff. Have fun!
Old Apr 3, 2001 | 01:55 PM
maxmizd27's Avatar
And furthermore...
You mentioned filling the wheel wells. That's where lowering springs come in. Not to be done with the wheels and tires. When changing wheel and tire size you need to keep the overall tire height as close (within 1/2") to stock height as possible. Any more than that results in gearing and speedometer problems. Just relized I forgot to address that earlier.
Old Apr 3, 2001 | 02:08 PM
KraZel
well look i dont have ne info on what he said...but it sounds like he know what he is talkin about. I just have to say that your ride is nice....It makes me proud to see another 89 in that good of condition!!! How many mile do u have
Old Apr 3, 2001 | 02:47 PM
ckcie
tire size...
Have you checked this site out yet. If not, this may offer some help. I've got 215/45-17's and my next set will be 235/45-17's
http://www.miata.net/garage/tirecalc.html
Old Apr 4, 2001 | 06:58 AM
maxmizd27's Avatar
You're darn tootin' I do
I was going to say, "No, but I slept in a Holiday Inn last night."
Old Apr 4, 2001 | 08:22 AM
90maxSE's Avatar
i have...
I have got 17's on my 90se, and I have 245/45''s they seem to fit in there perfectly, I am waitn for some good weather so i can put those rims on and then i will put up some pics.... just dont go any larger than a 45 because then you will offset the speedo, mine already is offset by 2mph at 60 which isnt a big deal...
Old Apr 4, 2001 | 09:13 AM
maxmizd27's Avatar
Upsizing 102
Keep in mind that the sidewall number (ex 45) is a percentage of the section width of the tire. Not the tread width. A 45 isn't the same height on a 215 wide tire as it is on a 245 wide tire. A 215/45 sidewall is 96.75mm. A 245/45 sidewall is 110.25mm. If you bump up to a 245 wide tire you're better off with a 40 sidewall, which is 98mm high. Isn't this fun?
Old Apr 4, 2001 | 02:46 PM
Chitwista's Avatar
Thank you for all of the help and information.. I decided to go with the 225 45 17.. And to answer your question I have a little over 80k on the car.. THNX
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
