replacing front wheel bearing
Old Aug 2, 2004 | 08:15 PM
shibbydevil's Avatar
how do i replace the right front wheel bearing on my friends 1991 maxima? i saw the replacment he had and it looked like a pressed in piece. Is that correct? Thanks
Old Aug 2, 2004 | 09:09 PM
subs1000w's Avatar
yes you have to press them in
Old Aug 3, 2004 | 08:59 PM
usaf_hydro's Avatar
I just change my right front wheel bearing about 2 wks ago. Its a simple job if you have the right tools for the job. the only problem I had was on of the bolts on the knuckle wouldn't come out, so I ended up pulling the whole strut assembly off the car. My bearing cost about $32 so it wasn't that expensive. The Chilton's manual was my best friend on this project..Good Luck!
Old Aug 3, 2004 | 09:36 PM
kcidmil's Avatar
Just pray your rotors aren't frozen on, like mine where when I was replacing them with the Brembo slots. The front right stripped 4 screws alone. Got ****ed and took a hammer to it. Other than that, bearings are easy if you have a press.
And hey, someone from the same area I am. WOW, I was beginning to think I was alone out here. Even though I've seen atleast 8 other 3rd gens.
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
BassAddictJ
Aug 4, 2015 11:38 AM
