! found wire brush in breather house!!!
! found wire brush in breather hose!!!
Holy **** I was trying to fix the connection on my CAI to the MAF to fix the air leak....and I took off the hose that goes from the intake to the breather tube(tube over the middle of the engine dohc) and there was a wire brush inside the hose....what sort of problems could this of been givin me?....now that I took the wire brush out will i get better mileage?
Originally Posted by DanNY
it's about 1/2-3/4 inch in length. center part of the wire is bend 90 degrees at the ends. wires are usually bronze in color.
Originally Posted by smokyman13
its like 3 inches long....2 thin white metal twisted like a pretzel...with wire brush on it in a circle......it almost looks like someone was using it to clean the tube...and forgot to pull it out.....
i'm pretty sure it's supposed to be in there. it's only air that passes that part. if you took it out it'll prob suck in actual oil. who in their right mind would attempt to clean a rubber hose?
keep in mind i'm referring to the VG...might be different on VE.
03VQMAX
Nov 10, 2015 03:39 PM
Hdnseek
Sep 9, 2015 05:55 AM
