loose antenna?
Old Aug 20, 2004 | 11:29 AM
sr20de's Avatar
loose antenna?
I recently replaced the antenna mast on my '91. It went in fine and works
but it seems loose. It wiggles back and forth a little bit when its extended.
I wondered if there was some kind of trick when you install it to "lock it in"?
Thanks for any info.
Old Aug 20, 2004 | 12:51 PM
maximagxe90's Avatar
Hi,
one reason your mast is lose because there isn't a washer on the antenna to hold it down in the motor,
if you want a washer you have to go to the junkyard and find a motor that has a washer in there,
i hope this help your problem,
Old Aug 20, 2004 | 01:42 PM
aw89maxSE's Avatar
I'm minus a mass too. Did you hook it back up to the power unit or is it just up all the time? If so, how hard was it?
Old Aug 20, 2004 | 03:44 PM
sr20de's Avatar
It was actually not too hard to fix. The plastic cable inside the mast broke.
I had to take apart the motor and get the broken piece of plastic out, put
the motor back together and re-install. Then threaded the plastic on the
new mast into the motor from above, turned the radio off and it pulled the
new mast down into the car.
here's a good explanation I found to help me:
http://www.4dsc.com/articles/exterio..._antenna.shtml
Old Aug 21, 2004 | 09:18 AM
bigkgs's Avatar
So what if you hear the antenna motor running...... and then it stops.
But the antenna hasn't been raised at all...not even an inch...
Recently I haven't heard the motor running anymore....Do i need a new motor, mast and antenna?
Old Aug 24, 2004 | 12:46 AM
sr20de's Avatar
Well, My motor was running trying to raise and lower the antenna but the plastic cable inside the antenna mast that does the raising/lowering was broken. If the motor isn't running when you turn the radio on or off I would guess the whole motor needs to be replaced.
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
