hood
Old Aug 22, 2004 | 06:42 PM
generation3's Avatar
hood
Sorry if this has been asked i couldn't find an answer on FAQ. Does anyone know how to fix the hood so that it stays up on its own. I know my hood used tos tay up by itself but now i have to put a wooden stake there or else the hood will fall on my head. If anyone knows how to fix this please let me know.
Old Aug 22, 2004 | 06:48 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
when my hood struts went bad, I found out the hard way...very hard.
Autozone, Advance Auto or Courtesy Nissan should have the replacement struts...someone posted the part numbers a while back, but I'm sure you can just go there and get them. think they were $35 or so
Old Aug 22, 2004 | 06:56 PM
thumpyls's Avatar
look no further.. http://internetautomart.com/ and he's an org. member
Old Aug 22, 2004 | 07:45 PM
«§»Craig B«§»'s Avatar
it's on my how-to page (in the FAQs)
Old Aug 23, 2004 | 08:47 AM
G9X4E's Avatar
Took out 2 hood struts on a 92 Max in a junkyard. Seems to hold better than my 94's, for some reason. 2 for $15. No drilling needed. Solved the problem for now. No more squashing danger of the head.
Old Aug 23, 2004 | 01:25 PM
Michael's Avatar
Back in a 3rd Gen.
hmm I think I would have spent another 15 for new struts and not have to worry about it for a while. I think I paid around $30 for mine brand new from advance auto. No drilling required on mine either. I may be wrong and they were a little more but I am pretty sure it was only $30.
Old Aug 23, 2004 | 03:15 PM
-shock211-'s Avatar
well...i've gotten quite accustomed to the hood falling on my head.
buy em' off internetautomart.com and solve your problem indefinately.
Old Aug 23, 2004 | 06:03 PM
internetautomar's Avatar
mod or sell?
$50 a pair shipped, brand new hood struts.
advanced was probably $30 ea. that's more in the normal ballpark
Old Aug 24, 2004 | 08:12 PM
kcidmil's Avatar
Well alteast I know I wasn't the only one to find out the hard way.
Old Aug 24, 2004 | 08:49 PM
Michael's Avatar
Back in a 3rd Gen.
I have a scar on my forehead from where the hood came down on me while I was close to the where the fender edge would be if it were on at the time. Instead the fender was off and the hood drove my head into the sharpe edges of where the body meets. It didnt feel too good to be hit in the back of the head that hard and then have the cut on my forehead from the edges.
I never worked on the car after that without a broom handle or something holding it up.
Heck even now with my new struts I still get a little nervous.
Old Aug 24, 2004 | 10:37 PM
dewmax007's Avatar
why opt for spending? just use that 6" vise grip which is taking up space in your tool box. lift the hood and clamp it onto the (nearest) hood strut. when you are done clamp it lightly, (yet tight enough not to loose it or damage what it is clamped to) some where out of the way, over say the cable that actuates the hood latch seems to work.
ya guess i am cheap, but have had other priorities to fix first. struts, windows, e-brake, brake pads. vice grip works worlds better than the custom broom stick. also better than my adjustable shovel used last winter. thought the hood would stay up during the summer. boy was i wrong. two nice divots from my jumper cables beautifully poking up above my battery. no my head was not in there!
bottom line, if you've got the disposeable income go for new!
Old Aug 25, 2004 | 12:09 AM
Maxzilla91's Avatar
my hood won't fall on my head, and it's difficult for it to fall on my head...
my hood struts are old and stiff as hell.. it takes a little bit of strength to lift it up, and takes equally much to pull it back down.. i guess i should be happy eh...
i tried to lube it up with WD40 but it didn't help.. but oh wellz.. as long as it holds it up my head is still safe..
Old Aug 25, 2004 | 05:09 AM
kcidmil's Avatar
Ouch, I thought mine was fine. It never looked like the struts were going or anything. And when I hung my drop light so I could finish taking off the intake. Next thing I knew my head neck is being pinched between the hood and the front bracket, and I'm staring straight at the cooling fans. Luckily it didn't cut anything, but I've been told I have a hard head
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
