master cylinder
Old Aug 25, 2004 | 02:08 PM
mjax10's Avatar
master cylinder
How do you know if your master cylinder is going bad ?? I bled the brakes from the master cylinder (matter of fact bled it 3 times very little brake fluid came out of brake line). I have to pump it a few times to stop. Autozone has new cylinder not rebuilt for 93.99.
Old Aug 25, 2004 | 02:26 PM
DanNY's Avatar
Ad·min·is·tra·tor
if you're MC is going dead then when you press the pedal you don't stop. it doesn't hold pressure or give u enough pressure to stop the car. it also can leak externally...that's when you know it's dead.
are you talking about wheel cyl in the drum brakes?
Old Aug 25, 2004 | 05:22 PM
mjax10's Avatar
no the mc itself. I have 4 wheel disc. I'm going to pick up a new mc after work. Thanks for info !
Old Aug 25, 2004 | 05:38 PM
5 ltr. beater's Avatar
Lucky for you I work at a brake shop. Your MC is going dead when you put your pedal to the floor and make a complete stop. After the vehicle has stopped, and without removing your foot off the brake; if your pedal sinks to the ground further than it did before the car was completely stopped, then your MC is going bad.
And by the way; why did you bleed the brakes in the first place? The only time you need to bleed the brakes is when you replace a caliper or a wheel cylinder. If you are just replacing the brakes, there is no need to bleed them.
Old Aug 25, 2004 | 07:34 PM
mjax10's Avatar
Thanks for the info. In that case MC is shot. That's exactly what I'm exping.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
