caliper emergency
Old Aug 29, 2004 | 07:51 PM
OBEEWON's Avatar
caliper emergency
i painted my calipers today, but i pulled the handbrake up while one of them was off for some dumb reason and i cant get the piston back in. ive tried everything i can think off. please help, thanks.
Old Aug 29, 2004 | 07:55 PM
Jay93SE's Avatar
Front or rear caliper? If it's the rear, you have to buy a caliper tool, or use a pair of needle- nose pliers in the notches in the piston to turn it back in. Thay don't push in.
Old Aug 29, 2004 | 08:00 PM
OBEEWON's Avatar
yeah its the back one. where are the notches? on the face of the piston? is it hard to turn?
Old Aug 29, 2004 | 08:04 PM
kcidmil's Avatar
sometimes you can get away with using a c-clamp, don't put anything in between the clamp and the piston. As you turn the clamp, it'll turn the piston. Hopefully it's not so far out, that the piston won't go back without removing the parking brake cable.
Old Aug 29, 2004 | 08:16 PM
Jay93SE's Avatar
Yea, the notches are on the face of the piston, there are 4 of them. It shouldn't be that hard to turn. The first time I did them, I used needle-nose pliers, the second, I bought the tool. The tool is easier, but if you don't want to waste thirty bucks, use the pliers.
Old Aug 30, 2004 | 05:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
buy the tool...screw it back in.
Old Aug 30, 2004 | 06:51 AM
OBEEWON's Avatar
ok thanks. i got it screwed in but now my brakes are all soft and the pedal sinks to the floor? what now?
Old Aug 30, 2004 | 06:58 AM
OBEEWON's Avatar
o yeah i remembered one last thing. when i was turning the piston i turned it the wrong way till it almost came out then i realized what i was doing then turned it the right way. is it possible that i got air into the system? if so would that cause my brakes to feel soft? how do i correct that? i have abs also. thanks for the help y'all.
Old Aug 30, 2004 | 07:09 AM
DanNY's Avatar
Ad·min·is·tra·tor
DEFINITELY bleed the entire system.
Old Aug 30, 2004 | 07:26 AM
OBEEWON's Avatar
ok where can i find instructions on how to do that?
Old Aug 30, 2004 | 07:29 AM
OBEEWON's Avatar
on an abs system
Old Aug 30, 2004 | 07:41 AM
Matt93SE's Avatar
STFU n00b!
also be sure to pull up the parking brake a few times and reset it if you've got your pads and rotors you want on there. sometimes that can be the issue as well...
do that before bleeding the brakes.
Old Aug 30, 2004 | 01:14 PM
-shock211-'s Avatar
the bleeder valves are on the calipers. they're covered up by a small rubber nub.
you'll need two people to bleed the brakes. one to work the bleeder valves and one to pump the brake pedal.
when bleeding the system you should start from the wheel farthest from the master cylinder. so start with the passenger rear, driver rear, passenger front then driver front.
make sure you are topping up the master cylinder level while bleeding the system too.
Old Aug 30, 2004 | 03:38 PM
medic's Avatar
does that work for abs also. I know what you listed is right for non-abs, but I thought abs was a presurized system so it was a different process
Old Aug 30, 2004 | 06:31 PM
OBEEWON's Avatar
Yes Will This Work For An Abs System? I Remember Seeing Something About Submerging A Hose In Brake Fluid While Doing This? Or Is That All I Need?
Old Aug 30, 2004 | 06:38 PM
OBEEWON's Avatar
if you could explain in detail or point me to a write up i would really appreciate it. i just want to know what im doing before i freak my brakes up.
Old Aug 31, 2004 | 12:10 PM
JohnnyWash1's Avatar
How do I tighten my parking brake cable?
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
