Inside tire thread wear
Old Sep 2, 2004 | 08:46 AM
G9X4E's Avatar
Inside tire tread wear
All my four tires are showing much more wear on the inside treads. I am about to go check the alignments of the suspension. But I heard not much is adjustable on our cars. Does my case means some suspension components are worn out? Any one with similar problems?
Old Sep 2, 2004 | 09:14 AM
Matt93SE's Avatar
STFU n00b!
are you lowered?
condition of suspension bushings? ball joints? tie rod ends?
does the car pull any?
there are many adjustments that can be made, but it depends on the problems.
sounds to me like your suspension bushings are worn out, which usually causes a toe-out and negative camber situation on these cars.
Old Sep 2, 2004 | 09:50 AM
G9X4E's Avatar
Not lowered. I'll check the bushings and stuff. Thanks for the info.
Old Sep 2, 2004 | 10:11 AM
Jeff92se's Avatar
I'm needing a caw
Old car = saggy springs = lower than before = pushes tires outward = excessive toe out = increases inner tire wear = 4 wheel alignment for toe = solution!
Old Sep 2, 2004 | 12:46 PM
Bman's Avatar
It's tread not "thread".... Sorry, pet peeve.
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Serotta33
Sep 17, 2015 12:14 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
jfl330
Sep 4, 2015 01:44 PM
