spark plugs
Old Sep 5, 2004 | 09:47 PM
boosted3rdgen's Avatar
spark plugs
anyone know where i can find some one step colder plugs for the VG
Old Sep 6, 2004 | 06:30 AM
domlcardio's Avatar
ngk.com.......
Old Sep 6, 2004 | 06:34 AM
domlcardio's Avatar
i think they are BKR6E-11
Old Sep 6, 2004 | 07:59 AM
Cliff Clavin's Avatar
Way out West
try NAPA. Just give them the part number and they will get it for you.
If you look in your owner's manual, there is a listing of the proper spark plugs.
Old Sep 6, 2004 | 09:17 AM
kcidmil's Avatar
Speaking of spark plugs. I'm going to take the dive here, since no one can tell me anything about Denso. So I figured I'd be the guinea pig here, and I'm praying I have as good as luck now with them. As I did with my 90 Nissan D21.
Now I'm sorry to post this, the test will not be until about Jan. I'm off for a 4 month vacation in the sand box, dodging mortars. So that means results won't be posted until about early feb (i need a few weeks to get a good feedback) Wish me luck everyone, I'm outta here tomorrow.
Oh, and the test will be compared against Bosch 4s.
Old Sep 6, 2004 | 10:36 AM
Matt93SE's Avatar
STFU n00b!
Dude, trust us.. just stay with NGKs. the cars really like them, and they don't like the others very well at all. I've tried the Bosch +4 and the Denso platinums and most of the others.
the VG really likes the NGK coppers and the VE will handle either NGK copper or platinum.
Old Sep 6, 2004 | 10:47 AM
thanks for the help...as for dom, i believe heat range on stock plugs are 11, which means i would need 10s
Old Sep 6, 2004 | 10:50 AM
95turbo gxe's Avatar
are you still auto with boost? I may have the axels from mine
Old Sep 6, 2004 | 11:03 AM
MrGone's Avatar
no its not
B= 14mm Thread Diameter
K= Hex Size 5/8" Projected Tip Construction
R= Resistor Type
5= Heat Range (5= Stock, 6= 1 step colder, 4= 1 step hotter)
E= V-Power (V shaped groove on the electrode, its only avaliable on the 14mm diameter plugs)
11= Plug Gap (11= .044", 10= .040", 13= .052" (they dont make a -12)
and quoting Matt, maybe if you read it twice you'll listen
edit: the only thing I will add to Matts thing is the cars are designed for them, thats why they like them so much
Old Sep 6, 2004 | 06:21 PM
domlcardio's Avatar
mrgone i thought the id without the s mean one step colder. maybe i was wrong but i know the one step colder are those i specified. thanks
Old Sep 6, 2004 | 08:54 PM
MrGone's Avatar
No, the S is standard (IIRC), basically ES = non V-Power, E = V-Power.
The heatrange is the number before that.
Also if your bored read the info on NGK's website.
Old Sep 6, 2004 | 09:48 PM
maximagxe90's Avatar
Hi,
the standard spark plugs for the vg is NGK BKR6ES-11
that is one step colder for the ngk spark plugs,
here is the ngk v-power spark plugs for the vg is BKR6E-11
hope this help,
ps: If you want to find out yourself go to this website and find out for yourself.
http://ngk.com
Old Sep 6, 2004 | 10:40 PM
MrGone's Avatar
Hi,
No it is not
FSM Pages for Proof:
VG:
http://www.digitalbeta.net/images/FSM/VG%20Plugs.JPG
VE:
http://www.digitalbeta.net/images/FSM/VE%20Plugs.JPG
Old Sep 6, 2004 | 11:15 PM
Hi mr gone,
which version fsm from the max do you have?
Old Sep 6, 2004 | 11:22 PM
MrGone's Avatar
It's out of the 1994 FSM. I'll find the actual version number if you really really want me to but meh.
Old Sep 6, 2004 | 11:35 PM
Hi Mr Gone,
i actually found the information from the ngk.com website,
i check my haynes manual to,
and it says BKR6ES-11,
iam not sure if it is or not,
i just found out that number is for the ve engine and not for the vg engine,
Old Sep 7, 2004 | 04:49 AM
internetautomar's Avatar
mod or sell?
NGK.com is NOT ngk's website. it is owned by an unrelated company that sell their products.
ngk's actual website is ngksparkplugs.com and they call for BKR6ES-11 for the VG (92 vintage) and PFR5C-11 for the VE which it's equivalant standard plug is BKR5ES-11.
and read this http://ngksparkplugs.com/techinfo/sp...000&country=US before anyone says anymore
Old Sep 7, 2004 | 10:41 AM
MrGone's Avatar
oops
Nissans FSM calls for a 5 heat range. I was taught to listen to the manufacture, I mean they did design the things. Also E > ES, not only cause the groove is cool, but also cause Kaleb says so
repost (I already learned that in highschool)
Old Sep 7, 2004 | 11:15 AM
ArcticDC5's Avatar
So, with the Bosch platinums I put in, is that the reason the car runs well at 1st, then when getting to operating temperature, its seems to bog down?
Old Sep 7, 2004 | 12:33 PM
mod or sell?
doesn't mean that they haven't updated the information since.
alot has changed since 94
Old Sep 7, 2004 | 04:53 PM
aminus21's Avatar
best spark plugs for 90 GXE Auto. I havent got a clear answer yet. I drive about 500 miles a week. with about 400 of them being on the freeway, at about 70-85 mph.
NGK V-Power??? which one..... part # please
Also what kind of wires.. RIght now I have some prestolites.. i heard that bosch ones suck.. NGK???
Old Sep 8, 2004 | 08:21 AM
domlcardio's Avatar
ngk man....
Old Sep 9, 2004 | 01:29 PM
ArcticDC5's Avatar
I bought some standard NGKs this afternoon. Do I need to gap them or are they pregapped already?
Old Sep 9, 2004 | 01:59 PM
Matt93SE's Avatar
STFU n00b!
should be pre-gapped, but I never take their word for it.
Old Sep 9, 2004 | 02:10 PM
92 Max's Avatar
Bosch vs. NGK
I believe the Bosch plugs have a little more resistance than the NGK, and this may be why the NGKs run better, i.e. a hotter spark.
Old Sep 9, 2004 | 05:27 PM
Minty91GXE's Avatar
internetautomart - which ngk's do you carry for the VG?
-M
Old Sep 9, 2004 | 08:41 PM
mod or sell?
the factory ones (can't remember the long # at the moment) they are just coppers. the VG doesn't require / use the platinums
Old Sep 9, 2004 | 10:06 PM
MrGone's Avatar
NGK has always been good about it for me. I still check incase one somehow gets messed with shipping but they've always been dead on or extremely close.
I've used NGK BKR5E-11's in VG's, VE's and VQ's all without any problems at all, Infact our VQ30DE-K is much better with the V-powers than the platinums.
Old Sep 16, 2004 | 03:11 PM
aminus21's Avatar
What does the maual mean by "hi-speed driving and hi-temperature driving"???
I drive about 300 highways miles a week @75mph...
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
