help, ecu code 1,2,3,4,5
Hi,
I checked my ecu. It flashed the following:
Long
short, short
3 (rapid blinks)
4 (rapid blinks)
5 (rapid blinks)
...repeat
It looks like 1,2,3,4,5 combination. I can't decipher the code. Can you please help me? Thanks.
Long
short, short
3 (rapid blinks)
4 (rapid blinks)
5 (rapid blinks)
...repeat
I did. Many times.
However, I can't figure what code number I have. Do I have code 12 34? I checked, and there's no such code.
Can someone just let's me know what code I have from the flashes I saw? Do I have multiple codes?
Thanks in advance.
Thanks in advance.
are you sure the 3 blinks after the 2 blinks were rapid, and not long? If it went 1 long 2 short 3 long 4 short or something id say you have multiple codes... but if its as you say somethings probably wrong with how youre doing it. id say double check the code pulling procedure, check the codes again, and post back
to get the code:
while the car running, turn the ecu dial fully clockwise. your red & green led will flash 2times. then turn the dial fully counter clockwise. your ecu is in diagnostic mode now. count how many times the red led blinks, then count the times the green led blinks. that is your code.
ex:
red blinks 3x
green blinks 2x
that means code 32.
in the sticky, there is a list of code meanings. refer there.
now to reset back your ecu. turn the dial again fully clockwise, wait till it blinks 4x, then turn it fully counter clockwise..your done.
hope this helps you out.
________________________________
i saw the skyline used in "2 furious" movie......i want one!!!!
ex:
red blinks 3x
green blinks 2x
that means code 32.
Thanks everyone.
Finally figured it out. Didn't know I had to have the car running. Anyways, I was able to extract code 55 (5 reds & 5 greens). Looking up the code, it means that "Normal engine management system operation is indicated." Cool!
Thanks again.
Thanks again.
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
