Normal when cold, sluggish when warm
First off, 1991 Max SE 5spd with 152k. Here is what has been done to it recently:
-Fuel injectors
-O2 Sensor
-Knock Sensor
-Water Temp Sensor
-Cat Converter
-Y-Pipe
-Cleaned MAF sensor
-Cleaned Intake plenum & ports
-Intake Manifold gasket
-EGR valve
-Idle Air Control Valve
-Fuel Filter
-Vacuum Lines
-PCV valve
-Bosch regular platinum plugs
-Cap/rotor was replaced before I bought the car
Since I replaced the knock sensor last week, the car does not sputter when accelerating and the timing seems to be a bit better. I thought that was the main problem. It still occurs: when the car is cold, the car feels amazing when driving, but when the temperature reached normal operating temp, it feels like I have lost 1/3 of the power. Does anyone have a clue whats going on here?
From what I hear, I should go to NGK standard plugs.
-Fuel injectors
-O2 Sensor
-Knock Sensor
-Water Temp Sensor
-Cat Converter
-Y-Pipe
-Cleaned MAF sensor
-EGR valve
-Fuel Filter
-Vacuum Lines
-PCV valve
Another thing that happens, if I am cruising abour 2,500 RPMs and take it out of gear to start stopping for a traffic light, the RPMs will suddenly drop down to about 400-500 then jump back up. I will try out some NGKs and see if there is any difference.
Knock sensor on the VG engine is on the block facing the firewall to the right of the exhaust manifold.
I already have a new IAC valve. I just came back from Pep Boys and bought some standard NGK spark plugs. I will see the outcome when I go change them once the engine cools a little.
Oh yeah! found the problem. While I was under the hood replacing my fuel filter. I just so happen to see an end of a wire with an eyelet on it just hanging down. I go over to see what it was. a ground wire for the injector harness was not attached to due an intake line blocking my view when I was making all the connections when I replaced my fuel injectors! So I borrowed a bolt from the bracket that holds spark plug wires and attached it. Now the car runs like a dream! its running on all 6 cylinders and before I am sure it was running on 5. I feel like I need to pay myself on the back. I really love my car now, runs so smooth with all those parts I replaced.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
