Beater
Old Sep 9, 2004 | 10:34 AM
rimmer1's Avatar
Beater
I'am picking up a parts car tonight. The car will start but then suddenly after a minute it dies.
1991 auto
Could this be the fuel pump ? fuel filter ?
Any help would be great so I can drive it home!
Thanx
Old Sep 9, 2004 | 10:45 AM
Maxima NutBag's Avatar
Could be the MAF as well. Make sure the connectors aren't corroded. If they are, coca cola trick them to clean them up enough where it will run.
Old Sep 9, 2004 | 10:47 AM
Jeff92se's Avatar
I'm needing a caw
-Fuel injectors
-O2 Sensor
-Knock Sensor
-Water Temp Sensor
-Cat Converter
-Y-Pipe
-MAF sensor
-EGR valve
-Idle Air Control Valve
-Fuel Filter
-Vacuum Lines
-PCV valve
-pugs
-Cap/rotor
Old Sep 9, 2004 | 05:48 PM
subs1000w's Avatar
Originally Posted by Jeff92se
-Fuel injectors
-O2 Sensor
-Knock Sensor
-Water Temp Sensor
-Cat Converter
-Y-Pipe
-MAF sensor
-EGR valve
-Fuel Filter
-Vacuum Lines
-PCV valve
-pugs
-Cap/rotor
haha
the sad thing is thats not a joke
Old Sep 9, 2004 | 08:43 PM
internetautomar's Avatar
mod or sell?
take someone with you who can do a quickie system check, that way you'll know where to start (if you can get that far)
DrVee
Sep 4, 2015 12:18 PM
evonder73
Sep 1, 2015 02:21 PM
DJMaxGLE
18
Dec 3, 2003 09:43 AM
ericdwong
Oct 5, 2001 09:51 AM
