water pum
Old Sep 12, 2004 | 03:50 PM
dragon_m's Avatar
water pum
does anyone have a pucture of all the bold in the 1992 nissan maxima GXE water pump. I took 2 of them on the top off but there is a 3 one some where i can't find it
thank
Old Sep 12, 2004 | 04:36 PM
internetautomar's Avatar
mod or sell?
can't say I do, but try using your fingers to feel around the edge of the pump for the other bolt(s) it's probably the easiest way
Old Sep 12, 2004 | 05:35 PM
Minty91GXE's Avatar
there are six or seven bolts on the water pump! 5-6 of one bolt and 1 of another type. don't take it off unless you're prepared to replace it... rtv sealant, thread locking compound, new gasket (new pump)
oh wait....
i know your problem. you see three nuts? you need to take the camshaft/timing belt covers off. thats about 18 bolts right there,
BUT you need to take the pulley off the water pump to get the covers off. (4 bolts)
-M
Old Sep 12, 2004 | 06:24 PM
floods943's Avatar
oh wait....
-M
(to dragon_m) exactly right, so while you're at that, it's a good idea to replace your timing belt and check the if you haven't done it recently.
Old Sep 12, 2004 | 07:53 PM
dragon_m's Avatar
I have never chage a timming belt before. I finally get my water pump off today. I plan to change the timming belt as well. I anybody give me some tip about the timming belt. I can't take the very bottom part of the timming belt cover off for some wear reason. It won't come off.
Old Sep 13, 2004 | 05:35 AM
floods943's Avatar
It is a huge PITA to get cover off, I did this job last year when I was in highschool in auto shop...and we sort of had a running bet out of the 5 of us who I asked...as to who would actually be able to get it off. Well, it took about 3 of us. (for the housing) I'm assuming that's what you mean by the cover. With all the bolts off, just pull like ****...think of how long it's been on there, haha.
I just noticed you're from Ann Arbor, I bet you're the only import on the road. Haha.
Old Sep 13, 2004 | 08:27 AM
Jeff92se's Avatar
I'm needing a caw
Please buy a service manual
Old Sep 13, 2004 | 08:46 AM
Knight4's Avatar
Or at least a Haynes...it'll be worth it!
Old Sep 13, 2004 | 08:47 PM
dragon_m's Avatar
I got the Maxima repair manual. I think this is a stupit question but my car when i turn it on the water in the radiator it seen like it doesn't move at all. All the cooling just sit in the radiotor and the radiator star to heat up realy bad and the cooland star to have smoke up. Is it a water pump problem. thank
Old Sep 14, 2004 | 09:15 AM
Knight4's Avatar
When you asked your initial question, it sounded like you had already started the process of removing the water pump. Maybe we need to go back to why you thought you needed to do that.
The behavior you described here sounds fairly normal to me. The coolent will sit still in the radiator until the thermostat opens up to allow cooler water to replace the hot water in the engine. Once it opens up, you should start to feel the radiator hoses get warm. If you have the cap off the radiator, which I wouldn't advise since this is a pressurized system, there will be steam coming up from the coolent. The radiator itself will also get hot to the touch. Even once the coolent is circulating, it will do so in pulses and you might not always see movement when looking into the radiator. The level of coolent in the radiator should always look full. The overflow container may show some fluctuation in the level as the coolent gets hotter and cooler.
If all this is happening, it would seem that both your water pump and thermostat are working fine.
Was there some other reason you felt the pump needed replacing?
Old Sep 14, 2004 | 05:42 PM
dragon_m's Avatar
I turn the engine on for about 5 minute and the radiotor got really hot but it seen like the cooland doesn't moving at all. the hose got really hot but it doesn't seem like water going to it. I just blow my old radiator a couple day a go so that why i think the water pump is bad. Just replace my thermostat a couple day a go
Old Sep 15, 2004 | 08:44 AM
Knight4's Avatar
If you take the belt off, can you grab the water pump pulley and wiggle it back and forth? Do you hear a grinding noise or any other suspicious noise coming from the water pump? Do you have any coolant leaking from the hole on the water pump itself (not sure if it is on the top or bottom of the shaft on the Max)? These would all be indications of a bad water pump. There might be more, but nothing comes to mind at the moment.
Also, does your temp guage indicate an over-heating problem? That would certainly indicate a cooling system problem of some kind.
I'm just kind-of throwing out ideas at this point. Not sure if you actually have a problem here or what it might be...
Old Sep 17, 2004 | 01:43 AM
bvtran's Avatar
94c Big Max
if you're going after the tbel proj, then consider changing the wp (every 120k) and the thermostat (every 60K) since you'll be spending so much time taking everything apart, it would be such pitta to do it again if you really needed to change these items. don't forget to change the seals too. if you got yourself a udp, then this would be the best time to do it cuz you'll end up taking it off too.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
