trans
Old Sep 16, 2004 | 11:11 AM
Nick93SE's Avatar
trans
Alright, for the past two days or so my car would not go into 1st, 2nd or reverse . Now i got it into reverse and a friend of mine got it into 1st and 2nd, but the it kinda ceased up again. So basically im gonna have to get a new tranny. Does anyone have a rough estimate of how much one with cost, and if they sell them at the nissan dealerships. thanks
Old Sep 16, 2004 | 11:13 AM
TIG's Avatar
TIG
I'm sure you have.....but have you played w/ the linkage?
Old Sep 16, 2004 | 11:31 AM
thumpyls's Avatar
does the 90 se trans fit?..if so theirs a parts car in jersey thats available,the owner got deported and left the title with his mom.she wants 300 for the whole car..i had a similar problem and i dropped the linkage and changed the fluid.mines was stuck in reverse for a while before it popped out. get a second opinion b4 u buy a trans
Old Sep 16, 2004 | 05:00 PM
Nick93SE's Avatar
ya im gonna bring it to a nissan specialist(a good friend of one of my friends), and have him check it out, before i buy a whole new trans.
Old Sep 16, 2004 | 06:41 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
interseting, my names nick and also own a 93 se 5speed however whats happened most likely to your car is the metal sleaves inside the tranny are worn to crap and the shift linkage is getting caught. I had the same problem, mine got caught in reverse and took a bit o' convincin to get it out. cost from lee myles 1900. The tranny had to be sent out to a specialist in NYC to be rebuilt. your welcome
Old Sep 16, 2004 | 06:44 PM
ghostmax's Avatar
I bought one from a 92 SE with 72K miles for $580 including tax. My other tranny still runs but the differential gear bearing needs replacement (made a wuh-wuh sound that drove me crazy). Usually the dealerships send them to a tranny shop and probably charge you a premium. You should take it to a couple of places first and shop around.
Old Sep 16, 2004 | 07:10 PM
Greeny's Avatar
¯\(°_o)/¯
Is it a auto or a manuel
Old Sep 16, 2004 | 07:41 PM
Nick93SE's Avatar
lol sorry didnt include that in my post, its a 5spd
Old Sep 16, 2004 | 09:44 PM
subs1000w's Avatar
does the car go into all the gears fine with the engine off
if it does it could be your clutch or posibly the master/slave cylinders
one thing to check is if your low on clutch fluid
other thing to do is check to see if your slave cylinder is moving when you push the clutch pedal in
also see if your low on trans fluid
Old Sep 17, 2004 | 03:53 AM
Nick93SE's Avatar
no it does the same thing with the car off.
I also checked the clutch, even though it smelled horribly because i basically had to start out in third the whole time it is working, might see if that is the problem though.
As for clutch fluid, it is in between min and max so that is fine
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
carlosvq30
Sep 26, 2015 09:44 AM
