ABS Sensor Locations????
Old Sep 17, 2004 | 07:07 AM
TIG's Avatar
TIG
For some reason search is not available to me and I read the ABS Sticky. I got a fault code for driver front wheel pulled the wheel off. I only saw the brake lines. I didn't tear into the caliber or rotor, is the sensor near the pad? Yep I'm a noob
Old Sep 17, 2004 | 07:10 AM
-shock211-'s Avatar
there's two lines in your wheel well. follow one to your caliper. the other leads to the abs sensor.
Old Sep 17, 2004 | 07:48 AM
TIG's Avatar
TIG
I must be blind I just saw the brake fluid line???? So I just follow the wire, it it visable on the front or is it in back of the nuckle by the ball joint and whatnot?
Old Sep 17, 2004 | 09:23 AM
Jeff92se's Avatar
I'm needing a caw
ABS sensors read the teeth off the gear located on the CV joint. Also read the stickies, that information IS in there.
Old Sep 17, 2004 | 09:45 AM
TIG's Avatar
TIG
Hip, I remember reading about the teeth but wasn't sure what they were talking about, I'll check out near the outer cv joint...thanks
Old Sep 17, 2004 | 10:47 AM
95turbo gxe's Avatar
Hey Im not trying to be an *** but If you get a haynes fsm it has all the layouts for the abs sensers and trouble shooting. For a long time I did not have one, but now that I went and got one it has taut me a lot and If I have question or wondering about something I can look in it to figure it out. Im not trying to tell you not to post but I thought it might would help you see things more clearly.
Old Sep 17, 2004 | 10:55 AM
TIG's Avatar
TIG
NP, I've had the car for 4 days, if I'll get a bentley once I buy tags
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
maximusrising
Sep 2, 2015 09:55 AM
