9004 to 9007 conversion write ups
Old Sep 20, 2004 | 02:15 PM
Loe max's Avatar
Does anyone have a link to do any 9004 to 9007 conversion write ups like in the 4th gen FAQ?
Old Sep 20, 2004 | 04:37 PM
RA030726's Avatar
I'm nutty for Nissans
http://www.vqpower.com/v2/modules.ph...howpage&pid=75
Old Sep 20, 2004 | 07:45 PM
thumpyls's Avatar
will this be easy to do.. whats the cost on this mod
Old Sep 20, 2004 | 08:46 PM
Loe max's Avatar
I don't think i'll ever get used to 45watt low-beams
Old Sep 20, 2004 | 09:42 PM
Harvs94max's Avatar
sweet this will look great with my new 100watt h3 in my foglights
Old Sep 20, 2004 | 09:49 PM
Loe max's Avatar
It should be easy, you just swap wires on both sides so you'll need some connectors which are cheapo. Plus you'll need 9007 bulbs, which are rated at 55/65watts and can be bought cheap anywhere. You'll just need to make sure the wires are the same color as the 4th gens, or you'll have to figure out which is the low/high/ground wire. Hopefully, someone with a 3rd gen manual can shed some light into this lighting matter.
Old Sep 20, 2004 | 10:15 PM
unsprung's Avatar
According to the directions, seems if you take the cheap route & just swap wires & file the nubs on the inside, this would cost you nothing.
If I go this route, however, will the stock wiring be able to handle the additional 10W for the low beam of the 9007 (55/65) vs the 9004 (45/65)?
Old Sep 20, 2004 | 10:36 PM
Loe max's Avatar
Well, If no one has done the conversion yet, I'll be the test dummy. If I end up melting a harness or wire, those aren't that expensive to pickup from a salvage yard.
Old Sep 21, 2004 | 01:17 PM
RA030726's Avatar
you should be fine, but the stock wiring sux no matter what. if you want the most possible light get a new harness.
Old Sep 23, 2004 | 10:21 AM
Loe max's Avatar
Does anyone have a repair manual for a 1993 Maxima?
The wire's leading to the drivers side headlights are :
Black = ground
Red w/ white strip = ?
Red w/ black strip = ?
The wire's leading to the passenger side headlights are:
Black = ground
Red w/ blue strip = ?
Red w/green strip = ?
Old Sep 23, 2004 | 11:44 AM
MrGone's Avatar
dont pay attention to the wiring colors, pay attention to the wire placement. The harness is the same because they are both 9004 bulbs stock. Hopefully that makes sense.
Old Sep 23, 2004 | 12:09 PM
Loe max's Avatar
Ahh the middle wire
Calabar
Oct 5, 2015 09:57 PM
ef9
Oct 4, 2015 08:43 AM
msellas
Sep 23, 2015 09:16 PM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
