Bad Slave Cylinder or Clutch/Flywheel/Pressure Plate
Old Sep 21, 2004 | 04:31 PM
DARHAW-MAX's Avatar
Greetings to all .ORG members.
What are the symptoms of a bad slave cylinder (MT)? The reason that I am asking is because I am starting to experience shuddering while taking off in 1st gear. To add to the frustration, it does not happen all of the time. Sometimes, I can take off with the smoothness of an automatic. At the next light, the car may shudder as if I was just learning to drive.
When I purchased the car last summer, the previous owner said that the clutch was replaced about 8 months prior to my purchase date (around July of 03); however, I am starting to question whether that is the case or not.
I am also asking about the slave cylinder because I do remember reading some time ago in the .ORG about them going bad. As of lately though, I have not read much about it.
I guess what I am really looking to find out is whether or not the intermittent—starting to become constant—shuddering can be caused by a bad slave cylinder or is it definitely clutch/flywheel/pressure plate related.
Thanks a million and one in advance for all of the info and replies.
Old Sep 21, 2004 | 05:13 PM
Greeny's Avatar
¯\(°_o)/¯
Shuddering is usually a sign that your flywheel needs to be resurfaced. also my have oil on the clutch surface.
Old Sep 21, 2004 | 06:55 PM
thumpyls's Avatar
good answer
Old Sep 22, 2004 | 05:24 PM
DARHAW-MAX's Avatar
Hey, thanks for the info. That is what I feared; however, a guy at work told me that I may be able to spray some carb or brake cleaner in through where the starter mounts to the tranny to clean off the oil--if that is what is in there. Nonetheless, are there any other opinions? I would still like to know the symtoms of a bad slave cylinder so that I can identify it when and if it does go bad. Again, thanks to all who read and replied.
matts95max
Apr 23, 2025 10:44 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
ricky7780
Sep 24, 2015 06:50 PM
