y-pipe question
Old Sep 22, 2004 | 04:57 AM
acidspit86's Avatar
y-pipe question
is the warpspeed y-pipe the one that has issues with ground clearance and clearance with the sway bar? also, does any one know where i can get a test pipe?
Old Sep 22, 2004 | 05:09 AM
D-sta's Avatar
The very first pipes they made I think had clearance problems, the new ones clear without a problem, even my car with the ST front sway bar I never had a problem.
Old Sep 22, 2004 | 06:49 AM
jmrader's Avatar
I have a warpspeed pipe and it fits perfect, no clearance probs..
Old Sep 22, 2004 | 07:11 AM
Matt93SE's Avatar
STFU n00b!
what they said.
email warpspeed about a test pipe too. they should be able to help you out.
Old Sep 22, 2004 | 09:58 AM
MrGone's Avatar
My WSP Y is higher up than the engine Cross member (I was hoping it would be) and clears the ST FSB
Old Sep 22, 2004 | 06:43 PM
thumpyls's Avatar
no
Old Sep 22, 2004 | 06:44 PM
KLoWnPR109's Avatar
I think the only people who had problems with the rubbing on the sway bar were those with the initial y pipes and then those who have bad motor mounts.
Old Sep 22, 2004 | 07:06 PM
aminus21's Avatar
is there a way to make a heat shield to replace the one that comes with the original y pipe??
Old Sep 22, 2004 | 07:32 PM
KLoWnPR109's Avatar
you dont need it, but yes, anything is possible
Old Sep 22, 2004 | 07:43 PM
James92SE's Avatar
2 VE's are better than one!
Where you been biatch?
Old Sep 23, 2004 | 12:49 AM
MrGone's Avatar
"studying"
if your having troubles sleeping because of no heat shields, then just get the damn thing ceramic coated
Quickywd01
Sep 21, 2016 09:36 PM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Socalstillen
Sep 26, 2015 12:01 PM
