Manual trany not going into gear.
Old Sep 23, 2004 | 08:29 AM
jmrader's Avatar
Hey guys I am in the process of swaping a manual tranny into my 91 GXE, I got the donar car from a salvage yard so I thought I should open the case on the tranny b4 I put it in my car to make sure all the gears and bearing were fine. Everything looked nice and wear free so I followed the service manuals instructions on putting the case back on. Now I can't get the freakin thing to switch gears, I don't have it in the car because I don't have the clutch yet but I hooked all the shifter linkage up to it to see if I could change the gears that way and it is still stuck in some gear. Did I do something wrong putting the case back together, It seemed to just slide right down together with no hassel. I thought it was fine but I don't know. Maybe it is just realy hard to shift until it is in the car I did'nt put tranny fluid in yet, would that have anything to do with it?
Old Sep 23, 2004 | 03:04 PM
fugi43's Avatar
Hey,
I had a similar prob in my swap. Try to find the check *****. They are located near the shifter mechanism within the case. If the springs and ***** are not taken out prior to splitting the case you could have a prob. Look in the srvc manual (FSM is best). It will tell you more. I have a VE FSM. I'd fax you a diagram if i had it for the VG.
Good Luck,
Matt Fugi
Old Sep 23, 2004 | 03:40 PM
jmrader's Avatar
I have a 92 service manual I used to take the case off and made sure to take the two detent ***** and springs out b4 I split the case, but I was trying to take the case off b4 I got the manual and I did'nt take one of the screws that went to the reverse idler shaft and reverse idler gear, I hope I did'nt break something..
Old Sep 23, 2004 | 05:16 PM
jmrader's Avatar
sorry fellas, I took the case back off again and looked down closely at the striking rod and noticed a little piece of white plastic blocking its range of motion. I guess when I took the case off the first time I failed to notice i knocked off the neutral safety switch connector, it comes out really easy and fell down to bottom of case,LOL oops..
Old Oct 1, 2004 | 08:18 AM
fugi43's Avatar
LoL,
I did the same thing. I'm glad to hear ya got it squared away. Enjoy the drive.
Matt
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
