1991 Maxima AC
Old Sep 24, 2004 | 11:07 AM
Logik's Avatar
1991 Maxima AC
My air conditioning didnt work in my Max when i bought it. It has the R12 stuff in it. So i went and bought a R134 retrofit kit and tried putting the adaptors on the high and low side of the ac system. The high side fit fine but the low side adaptors wont fit... none of them. I went to Auto Zone and they tried all the adaptors they had and none fit. They said that it was because it was a nissan
Any ideas of what to do to fill my ac system with R134? thanks.
Old Sep 24, 2004 | 11:19 AM
internetautomar's Avatar
mod or sell?
1 if you have R12 in it, you have to have a MACS Certified person remove it before doing anything.
2. have it charged off the high side though you'd probably have to take it to a shop, unless you have the machine at home
Old Sep 24, 2004 | 11:35 AM
Logik's Avatar
then why do they make a retrofit kit?
Old Sep 25, 2004 | 01:36 AM
nubiannupe's Avatar
OG Maxima.org Member
Well, hold on, B... all of that shouldn't have ANY bearing on the adapters fitting or not. At least, when I used the retrofit kit for MY max, it didn't make any difference....
I simply got the kit, screwed on the adaptors, drove to my mechanic's shop and had them charge off the 'old' R12, took it back home and filled it up with the R134a - carefully, of course...
Now, if - Logik - you're deciding that it'd be a heckuva lot cheaper to just purge the R12 right in the driveway rather than take that drive and have it done "pro-style", DON'T!!!! That's where what Brian said comes into play.
Maybe your threads are damaged, which is why your adaptors won't fit. Did you check 'em?? That whole "...because it's a Nissan" thing is just someone's way of blowing smoke up your @$$, IMHO. They probably drive a Ford Festiva, too...
What's the name of the kit you bought? I got mine at K-Mart, so maybe it's a different kit. That's always a possibility, too...
Food for thought.... do the dishes...
Old Sep 25, 2004 | 08:13 PM
mod or sell?
The kit is for systems that are empty and under vaccum.
unfortunately they are very misleading, my uncles shop does the retro & recharge for like $125 which isn't that much more than what one would have to pay for Removal of the R12 (has to be stored , can't just vent it + EPA BS) retro kit ($35 with 2 cans R134a and oil) + Vaccum (which should actually be held from step 1)
of course that is my .02
Companies make products that aren't always useful, but people like to buy their own parts anyhow
Old Sep 25, 2004 | 09:01 PM
rcy's Avatar
rcy
Do you know for sure why the A/C isn't working. There's no point in dumping R134 in there only to find out that there's a leak in the condensor and all that R134 will soon be contributing to global warming. It's probably too late for you, but if the system is not working only because it's low on charge (due to a very minor leak over the last 13 years) I would bit the bullet and pay the extra to have it topped up with R12 rather than doing the R134 retrofit.
Old Sep 25, 2004 | 09:18 PM
alpicone's Avatar
Around here you can get a can of r-12 for about $10. Most shops will add it for you for $35 (including cost of can).
Old Sep 26, 2004 | 04:12 AM
nubiannupe's Avatar
That's a good point, rcy... I didn't even THINK about there might be a leak. Pressure testing the system might be their first point of focus.
Old Sep 26, 2004 | 04:16 AM
bhunter's Avatar
I agree with rcy. Have someone shoot a little R 12 in there and see if it even works. R12 is the global warming stuff though, not 134. (so far)
Old Sep 26, 2004 | 07:40 AM
mod or sell?
I think you're confusing the 12 with 134a
R12 runs around $30 a can (which is only 12 ozs) and you need to be certified to buy it.
The 134a is like $3.50 a can and no certification required.
Old Sep 26, 2004 | 07:44 AM
alpicone's Avatar
Well not it Brooklyn. I know of a store that anyone can walk in and buy a can. And I got a can added to my system for $35 cause I wasnt sure if the prob was that it was just low. So I paid someone to check it.
Old Sep 26, 2004 | 07:56 AM
mod or sell?
hmm... can you say "In violation of federal law"?
I also know of stores where I can go buy a joint for $10 and they'll smoke it for me for free
Old Sep 26, 2004 | 08:56 AM
Greeny's Avatar
¯\(°_o)/¯
I don't think they even produce R12 in 12oz. cans anymore
Old Sep 26, 2004 | 09:01 AM
Greeny's Avatar
¯\(°_o)/¯
My bro-n-law is certified for that stuff. He can only buy it in large canisters {look like propane tanks}
Old Sep 26, 2004 | 12:47 PM
mod or sell?
they don't make it here in 12 oz cans, but 3rd world countries still make it, and some gets into the stores here.
Old Sep 26, 2004 | 04:27 PM
rcy's Avatar
rcy
Actually, they both contribute to global warming (perhaps one more than the other). The real problem (and difference between the two) is that R12 eats holes in the ozone layer. R134 does not.
Old Sep 26, 2004 | 06:42 PM
avmaldo's Avatar
R12 is cooler though
Old Sep 26, 2004 | 08:50 PM
Logik's Avatar
thanks for the info guys.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
