fuel pump just quit?
Old Sep 24, 2004 | 01:56 PM
broncoguy's Avatar
OK, this seems a little wierd, but maybe that's how these things go out. I've been changing out injectors, so I pulled the pump fuse to release the pressure. Got everything back together, put the fuse back in, turned the key....nothing. No fuel pump noise at all. Cranks fine, but no fuel.. checked the fuse, it's fine. Can the pump just die like that, or is there soemthing else I'm missing?
Old Sep 24, 2004 | 02:55 PM
Greeny's Avatar
¯\(°_o)/¯
Try banging on the bottom of the gas tank.I was 600 miles away from home when my fuel pump died.so I smacked the tank with a wrench and got it back going till i got it back home. It also confirmed the problem.
Old Sep 24, 2004 | 02:58 PM
subs1000w's Avatar
you need to check to make sure you have 12 volts getting to the pump it could be a stuck relay also
Old Sep 24, 2004 | 03:02 PM
broncoguy's Avatar
OK, I'll check those things- thanks for the replies!
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
