that black thing in the trunk...
So there was thread a while back about the thing that sits under the trunk carpet directly behind the rear seats, but i cant find it at all. So does anyone know what it is or what it does? OR can i just take that thing out.
Gregg
Gregg
Keep looking.
Gregg
Gregg
Originally Posted by anaximander
20lbs more in the trunk will make it neither heavy nor slow (which the gxe already is). If anything, it'll minimally correct the understeer bias.
YES!!!!!!...1st answer that made sense.
But how on Earth it will achieve that consistently with any combinations of load in the trunk, on the floor and with the people on the seats? There is no way that weight can serve as a correction under all circumstances! Only under some...
Because it doesn't and it's purpose is to dampen noise.
Originally Posted by VG Ill ridah
Also in that case why is it only found in GXE's. If you wanted to correct such a problem then why not give it to the sportier SE maxima's.
Are you sure? Imagine if you load the rear with a really heavy weight. ie.. huge speaker box etc.. Then imagine if you took out a large amount of weight. You think adding weight would make the rear oversteer more or less? Making the rearend very light would tend to make it more slide happy IMHO. ie.. a truck
Because it's not in there for that purpose, but like jeff said to dampen noise. They delibarately produce the cars with an understeer bias for safety purposes (let alone the fact that fwd's are naturally understeering). That's why I said "minimally"; adding any weight to the rear will correct understeering but only to the extent of its mass.
adamgalazka
Feb 5, 2023 08:24 AM
ballerchris510
Sep 10, 2015 09:35 PM
doctorpullit
Sep 10, 2015 06:33 PM
03VQMAX
Sep 5, 2015 03:47 PM
