Whats The Best Intake
Old Oct 2, 2004 | 04:33 PM
Duckman540i's Avatar
VE Powah!!!
What do you think is better for a '93 SE??? Place Racing CAI, JWT Popcharger, or the Stillen Intake?
Old Oct 2, 2004 | 06:27 PM
Cliff Clavin's Avatar
Way out West
piggie racing intake...
Old Oct 2, 2004 | 09:20 PM
MrGone's Avatar
mine
10worthlesscharacters
Old Oct 2, 2004 | 11:05 PM
Michael's Avatar
Back in a 3rd Gen.
well the best intake is the one you can afford .
I like how Jeff makes one that goes behind the headlight.
I bought a cheap one off of ebay that is basically the same as PRI but is aluminum instead of steel. I think I paid less than $50 shipped for it. You can see it on my site.
Old Oct 2, 2004 | 11:40 PM
mtcookson's Avatar
i personally think the turbocharger intake setup is one of the best...
seriously though, i'd support an org member and buy one off of Jeff if he is selling them.
jwt pop charger is too expensive for what you get and stillen usually charges out the *** so i wouldn't go with either of those. place racing should be pretty good if you want to go that route.
Old Oct 10, 2004 | 03:16 PM
dadonfromqueenz's Avatar
would a 92-94 intake fit in a 91 maxima?
Old Oct 10, 2004 | 03:19 PM
AscendantMax's Avatar
depends. if it's just a regular cone intake with a MAF adapter then yes it'll fit. but if it's a CAI, then it won't. there are different bends in the pipe for the VE and VG engines.
Old Oct 10, 2004 | 03:33 PM
reygarcia's Avatar
Loved by MrGone longtime
YES!!! if you should definately get your hands on a Piggie Racing intake.
Old Oct 10, 2004 | 05:20 PM
internetautomar's Avatar
mod or sell?
Don't you mean wrap your hands around Piggie Racing
Old Oct 10, 2004 | 11:25 PM
VE Powah!!!
Where do you get a "Piggie Intake" never heard of it LINK?
Old Oct 11, 2004 | 03:20 AM
vqman
a cheap one..
Old Oct 11, 2004 | 05:05 AM
It's a long story...
Old Oct 11, 2004 | 07:42 AM
mod or sell?
Believe me, you don't want to go there
Old Oct 11, 2004 | 09:57 AM
where can i find a CAI for a 1991 Maxima GXE?
Old Oct 11, 2004 | 10:20 AM
94M@X's Avatar
http://forums.maxima.org/showthread.php?t=126113
Old Oct 11, 2004 | 12:48 PM
Bman's Avatar
Jeff92se's CAI: http://forums.maxima.org/showthread.php?t=312849
I like how it requires less cutting and places the cone filter in a much better place than with normal CAIs which go through the fender. I probably would have bought this instead of a (used) JWT popcharger if it had existed back then.
Old Oct 26, 2004 | 10:30 PM
VE Powah!!!
Popcharger Intake?
I know that these popcharger setups from Stillen & JWT give you a few horsepower & a mean growl, But seeing as how they sit open in the engine compartment they are exposed to all the engine heat, therefore as soon as the car heats up it should actually lose some horsepower due to hotter air going in the combustion chamber. Just wanted to see what you guys thought, or if you 've had experience with them? Some input please THANX
Old Oct 27, 2004 | 12:07 AM
bonzelite's Avatar
i will *speculate* that because the pop charger is a direct, straight, unobstructed pipe, it will allow air to pass more efficiently into the intake manifold, regardless of the heat issue. therefore, more air will get in quickly, even if it is warm; perhaps the pop opening is remote enough from the exhaust manifolds to get some ambient outside air coming in from the grille.
but forget it anyway. get a CAI. save another few bucks and start right. run it to the fender well.
Old Oct 27, 2004 | 07:56 AM
unsprung's Avatar
Most of us end up making the pop charger, or HAI (hot air intake), as our first mod (after a FSTB, of course) because it's cheap & it's gives the engine a bit more growl.
If you're looking for performance, everyone will tell you to go CAI & it's true (esp since you drive a VE & I believe the CAI is available on eBay for you guys at ~$60-$80).
If you're looking for a cheapo mod that, to my knowledge, hasn't caused any harm yet, go for the pop setup. Some say you lose minor low end torque while gaining a bit of top end, but don't count it for anything more than 1-2 hp. Maybe a bit more on the butt dyno , but if you go this route, do it mostly for the sound
Old Oct 27, 2004 | 08:42 AM
Jeff92se's Avatar
I'm needing a caw
http://community.webshots.com/album/145789293SyrMnu
Custom cai. No huge holes in your sheetmetal.
Old Oct 27, 2004 | 08:44 AM
Jeff92se's Avatar
I'm needing a caw
This question again??
Old Oct 27, 2004 | 01:28 PM
MrGone's Avatar
technically no holes at all
Old Oct 27, 2004 | 04:29 PM
VE Powah!!!
Is there anyone that has just hacked there stock airbox? Where do you cut it at & what kind of gains to expect? Also that + K&N should be nice setup
Old Oct 27, 2004 | 04:32 PM
Jeff92se's Avatar
I'm needing a caw
A long time ago in a galaxy far away, I tried a K&N panel. It actually worked when it was VERY new or VERY clean. Once it was used for a bit(ie.. 1 week), the improvement went away. This was on a stock non-hacked airbox. If you hack you airbox, you lose all the benefits that the stock air horns give you anyway. You still have to use the stock sized panel filter and now you are getting air from the engine compartment.
Old Oct 27, 2004 | 07:58 PM
MrGone's Avatar
wtf is a air horn?
Old Oct 27, 2004 | 11:38 PM
xMaxed90x's Avatar
I believe there is a deal for the Place Racing CAI in the group section you might want to check that out...
Old Nov 6, 2004 | 12:22 AM
VE Powah!!!
CAI Intake
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634 What do you guys think of this CAI?? Worth it??? Hows the quality??? Should I just save up & get Place Racing? Thanx
Old Nov 6, 2004 | 12:57 AM
Lordrandall's Avatar
Several guys here have similar intakes, that one should be fine.
The only thing I would be worried about is a crappy filter.
Old Nov 6, 2004 | 02:55 AM
MrGone's Avatar
I believe that is the same kit as michaels. He just said its made of aluminum instead of steel. Like Randy said, I would be weary of the filter.
Old Nov 6, 2004 | 07:50 AM
5 ltr. beater's Avatar
Buy it already and quit stalling!!!!!!!
Old Nov 7, 2004 | 06:03 AM
goon9's Avatar
Somethins to consider about CAI's. There's a red turbo VE that got hydro locked with the air filter located in same place ur all hooking up ur CAI's.
Old Nov 7, 2004 | 06:09 AM
Greeny's Avatar
¯\(°_o)/¯
What is "hydro locked"
Old Nov 7, 2004 | 06:43 AM
Michael's Avatar
Back in a 3rd Gen.
Yeah it can happen but as long as you stay out of big puddles (and it would have to be a big one) then you should be ok.
That is indeed the same intake I have. I got it from a different supplier though. A friend of mine made a template for it and I have it posted on my site. the link is in my sig.
Old Nov 7, 2004 | 10:44 AM
mod or sell?
When you get water in your engine and the engine stops turning
Old Nov 7, 2004 | 11:20 AM
Greeny's Avatar
¯\(°_o)/¯
Thank you again mr. internetautomar you once again have pulled me from the depths of ignorance and educated me.
Old Nov 7, 2004 | 01:16 PM
mod or sell?
Been there done that
Old Nov 7, 2004 | 03:32 PM
Evil_Twin's Avatar
So what about air bypass valve ( I think thats what it's called). Does that actually work?
Old Nov 7, 2004 | 04:05 PM
Jeff92se's Avatar
I'm needing a caw
Try subscribing to your threads so I don't have to keep merging all your related questions. I'll just delete repeated threads in the future
Old Nov 7, 2004 | 07:33 PM
Bill Brasky's Avatar
Seperated at Birth?
shh. it's a sekrat!!11oneone
Old Nov 7, 2004 | 07:38 PM
MrGone's Avatar
Originally Posted by antonthegrey
!!11oneone
welcome to the internet!
Just buy antons if you have a VG, buy Jeffs if you have a VE, or just dont bother all together
