Power Windows not working
Old Oct 12, 2004 | 05:39 PM
ian999's Avatar
All of my power windows are not working. Checked the fuse near the battery and all the fuses under the driver side fuse box. There is 12V power at the driver side control panel (Red and white wire and white wire when the ignition is on). The glove box light is also off.
Old Oct 15, 2004 | 05:05 PM
waffqle's Avatar
I had the same problem in my 93 not long ago. I fixed it by replacing the main control panel. I apologize for forgetting the actual name of the part, but it's the panel with all the window/lock buttons on the drivers door. It ran me $120 at the dealership. It might be worth mentioning to you that I could still roll the windows down from the keypad on the outside of the door.
Old Oct 17, 2004 | 03:17 PM
ForceFed's Avatar
If it is your master window control switches, you could check out ebay. There are always some on there for like 10-15 bucks. They're used but some sellers offer a warranty. Your problem sounds electrical though, especially with the glove box light out.
Old Oct 18, 2004 | 02:52 AM
nismobaron's Avatar
Master window switch a common fault - the glovebox light is probably coincedence as it runs off the interior light circuit, and that would mean the transmission selector light, the aircon lights etc would be out as well.
I'm assuming that the power windows have been working up to this point - if you've just got the car & they haven't worked from day one, someone may have had the drivers door panel off & not plugged the connector back into the switch - check this as well. Good luck.
Old Oct 18, 2004 | 04:39 AM
redart's Avatar
Or it could be that all four of your window regulators are shot.....like they were in my '91 J30. Now that'll cost you!. Can you hear any noises when you operate the switches.....like the motors trying to turn?
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
