Headlight out, not the bulb.
Old Oct 15, 2004 | 05:34 PM
waffqle's Avatar
My passenger side headlight went out the other day. I went down to the parts house and got a couple new bulbs without even thinking about it. I put em in, but it still doesn't work. Perhaps I'm missing something obvious, but I haven't got a clue what to look for. The wiring (atleast the visisble portions) look fine, no bad fuses, I'm stumped.
Thanks,
Waffqle
Old Oct 15, 2004 | 09:49 PM
AscendantMax's Avatar
were you using aftermarket lighting? (xenon bulbs, etc etc)
Old Oct 16, 2004 | 12:31 AM
JoeNismo92SE's Avatar
Just went through the same problem, it's your headlight switch on the turn signal stalk, and it aint cheap @ 110 bucks. hopefully you can do it yourself because my bill came to 277 bucks with the labor. You have to remove the steering wheel to replace it. Good luck
Old Oct 16, 2004 | 09:29 AM
MaximamixaM's Avatar
Not sure by your description, and maybe this causes other problems, but something to check is the two fuse relays under the hood for the headlights. Swap them and see if the other headlight stops working correctly. Otherwise might be the steering wheel stalk headlight switch.
Old Oct 17, 2004 | 10:11 AM
markmaxima's Avatar
you might want to check the socket, and make sure the socket isn't worn out,because i use brighter bulbs but the sockets don't last to long, check that before you waste time/money
Old Oct 17, 2004 | 10:24 AM
Greeny's Avatar
¯\(°_o)/¯
WOW! thats outrageous. did you or your mechanic buy the part.check this link out.http://www.autozone.com/servlet/UiBr...C%7EElectrical
Old Oct 17, 2004 | 07:56 PM
Ninty-two-se's Avatar
I replaced mine and I did not have to take off the steering wheel to change it.... just the plastic behind it,which is held on by screws in the underside of the 2 pieces. try the junkyard to see if you can get it cheaper if that turns out to be the part you need. My symptoms when my switch burned out was that the highbeams wouldn't switch on.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
