If not lines on fuel rails, where is smell coming from?
Old Oct 19, 2004 | 05:46 PM
pest55's Avatar
I replaced every inch of fuel line under the hood of my 89 SE back in January b/c the driver side line on the fuel rails was leaking. That took care of the smell until just a couple of weeks ago. This time it does not go away after the car warms up; it is very strong every time I stop. It appears that there is gas leakage at the tops of two injectors, not where they seat into the fuel rails. I actually replaced all of the o-rings on the injectors and the big gaskets that they seat down into a few years ago. Does my problem sound like injectors need to be replaced or can the injector be resealed (if that makes sense)?
Old Oct 19, 2004 | 05:51 PM
Greeny's Avatar
¯\(°_o)/¯
Sure sounds like you need new injectors.
Old Oct 19, 2004 | 08:14 PM
89badmaxse's Avatar
i wish i coudl figure out why mine smells like fuel it doesnt smell under the hood though it smells inside the car the enigne is clear of seeps and leaks what would make the smell inside the car but not under the engine bay at all
Old Oct 19, 2004 | 08:50 PM
thumpyls's Avatar
pull ur plug wires one at a time,if it bogs then ur injectors good.if it stays at a quiet idle then ur injectors shot
Old Oct 20, 2004 | 05:47 AM
tripleGmax's Avatar
i have a two broken bolts on my manifold, does anyone think that could be where my gas smell is coming from? I only get the smell when the engine is cold, not after its warmed up. I have checked all the lines and they are solid. I guess i could check my injectors next.
My buddies quote after riding in the car with me the other day "i used to like the smell of gasoline, but not now dude. Youre car is stinky"
and i dont want a stinky car
Old Oct 20, 2004 | 01:28 PM
Maxim93's Avatar
Have you check the fuel pump? Pull out the rear seat. Also, when you fuel the car up, don't try to top it off by squeezing the nozzle trigger repeatly.
Old Oct 20, 2004 | 01:31 PM
Jeff92se's Avatar
I'm needing a caw
I believe VGs have rubber lines attached to the tops of the injectors. Those could be old/cracked/leaking? Common VG problem.
Old Oct 20, 2004 | 02:33 PM
broncoguy's Avatar
I think those rubber lines on top are only on the pre-89 versions. 2nd Gens have them that way. My 90 VG has "regular" ones. But, since he says that there's fuel seeping from the tops of the injectors, I would say the injector itself is leaking.
tripleGmax- your manifold studs wouldn't cause a gas smell. An exhaust smell maybe, but not gas.
Cotozic
Jun 28, 2017 08:01 PM
cruce91
Sep 20, 2015 10:23 AM
Johnny9595
Sep 3, 2015 05:18 AM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
