testing harness
Old Oct 22, 2004 | 11:12 PM
blacks92seAuto
testing harness
I went to test my harness on my knock sensor to see if its working....what side of the harness to i check for resistance? do i check the harness going into the main wire harness or the one that goes to the KS? also.. if I unplugged my knock sensor would it run like the car is cold?
Old Oct 23, 2004 | 08:08 PM
blacks92seAuto
edit: would unplugging the knock sensor harness make the engine run as if the knock sensor is good? or could you get a new knock sensor, and just plug it into the harness and not necesarily put the sensor in the motor....just lay it somewhere and plug it in? would that work?
Old Oct 23, 2004 | 10:07 PM
Mizeree_X's Avatar
Getting back to his roots
To simulate a good knock sensor, place a 470kOhm resistor across the 2 prongs of the harness (ECU side). The ECU side is the side that is NOT coming from the valley of the engine. DON'T drive your car around for an extended period of time like this, use only to help diagnose a bad knock sensor.
Old Oct 24, 2004 | 11:14 AM
blacks92seAuto
where can I get this 470k ohm resitor at? im asuming at any schucks o radio shack, what does it look like and how exactly do i place it across the 2 prongs? maybe if I saw a picture of one Id understand
Old Oct 24, 2004 | 11:15 AM
blacks92seAuto
thanks for the help by the way, sounds like a good way to diagnose my problem, thanks
Old Oct 24, 2004 | 11:31 AM
blacks92seAuto
should I use the 1/4watt 470k ohm resistor or the 1/2watt one? and how do you attach them to the terminals?
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
zmcneely13
Sep 26, 2015 02:26 PM
