92se lacks power
Old Oct 31, 2004 | 09:14 PM
Jeff583's Avatar
92se lacks power
my 92 se runs ok but not great when its cold and when its warm it runs very weak seems to lack a lot of power in the lower rpm range and a little lack of power in higher rpms, i am not exactally sure what this is but i am guessing somthing with the timing but i can use all the help i can get
Old Oct 31, 2004 | 10:10 PM
blacks92seAuto
sounds like a bad knock sensor...if it has over 100k miles on it replace it
Old Nov 1, 2004 | 03:08 AM
Greeny's Avatar
¯\(°_o)/¯
My vtc selonoids were the cause of my heat soak problem.I grounded mine{to broke to fix them } I also did the 470k resistor mod on the ks. If you do these this you need to use 93 octane. otherwise it will clack like a cummins diesel.
Old Nov 1, 2004 | 06:24 AM
Cliff Clavin's Avatar
Way out West
It wasn't your VTCs, it was the KS you bypassed with the resistor mod...
This is not the greatest idea. Loosing a little power is a lot worse than loosing your engine.
You both need to replace the KS and the KS subharness. Parts are around $150 shipped (from Courtesy Nissan) They were cheaper than the two dealers I called near me.
Courtesy KS
Old Nov 1, 2004 | 02:02 PM
Greeny's Avatar
¯\(°_o)/¯
Courtesy KS
I disagree because i did the resistor mod first, did not help. Then i grounded the vtc's whoa! what a difference. I grounded them a year and a half ago and 60,000 miles later and the engine is just fine. so if grounding them causes damage to the engine i think the thing would blown up a long time ago. I would prefer to fix them but i do not have the$$$$ to do it.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
