HIGH idle in Neutral and Park
Old Nov 1, 2004 | 09:44 PM
nuch's Avatar
My 92 GXE has high idle while in Neutral and Park, however while in drive its perfect around 700-900rpm.
When I say high, during warmup its around 1800-1900rpm, then it drops to around 1400-1500rpm.
However As soon as I put it in drive or reverse it drops right down into the normal operating range of 700-900rpm.
I have cleaned/replaced the IACV, cleaned the throttle body, checked/replaced the TPS, cleaned/replaced the MAF, changed the O2, changed thermostat, EGR valve.
Not sure what else it could be?????????
Old Nov 2, 2004 | 04:47 AM
DMad8724's Avatar
Coolant Temp Sensor? I know I need to replace mine and I have the same idle problems you do..
Old Nov 2, 2004 | 06:08 AM
Harvs94max's Avatar
its pretty normal to have an initial high idle your car is just warming up the coolant temp might help but if it dosnt dont be alarmed its normal as long as it drops back down when you put it in drive.
Old Nov 2, 2004 | 06:56 AM
nuch's Avatar
Nissan sold maxima's coming out of the lot reving at idle at 1500rpm in park?
hmmmmm don't think its normal, although I have become accustomed to it being normal since I can't seem to fix it.
I will change the temp sensor, where is it located, and how much do they run?
Any idea?
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
