Transmission: Power, A/T, or Comfort
Old Sep 28, 2000 | 10:07 AM
roman's Avatar
I have a 93 GXE with Auto transmission which has three modes: A/T, Power and Comfort. I really like driving the car in Power mode because there is significantly better acceleration and the ride is much more fun.
My question is: Is this bad for the transmission or engine? Should I usually be in A/T mode and when I want to pass, switch into Sport or O/D?
Someone please help me out.
Thanks,
Roman
Old Sep 28, 2000 | 12:03 PM
speednsound007's Avatar
switch
being in power wont mess up anything, it just has the engine revv higher before switching (giving better performance) you can leave it in there if you wnat the only problem is you get bad gas mileage.
PJ
Old Sep 28, 2000 | 12:18 PM
roman's Avatar
Thanks for the info.
Thanks for the reply. Anyone have any other comments about this?
Old Sep 28, 2000 | 01:19 PM
Richy92SE's Avatar
what about comfort mode, when its best to use this mode?
Old Sep 28, 2000 | 01:29 PM
chris92gxe's Avatar
Re: Thanks for the info.
For some reason I cant tell a difference between power and comfort. When the switch is set on normal and I floor the gas the power switch lights up. The guy at the transmission shop said the switch is supposed to change the suspension settings too. I personally dont see any changes in anything. Can you really tell a diference or is it just in your head?
92GXE, touring wing, 18” racing wheels, Port&Polished intake, custom intake, custom yellow interior, racing seats, back seats taken out and replaced with subs and amps, NOS kit, Suspension tech. Lowering springs, custom grille, soon to be custom painted and have the whole engine rebuilt for big shot NOS and custom SC and tranny converted to 5-speed.
DanNY's Avatar
Ad·min·is·tra·tor
comfort:
when you don't want to rev too high during driving. PROS: less engine noise and higher gas mileage. CONS: less power.
power:
engine will delay the shift..IE wait until engine revs higher before it shifts. PROS: more power CONS: lower MPG, more engine noise. used when racing or driving hard.
in the middle:
the computer will determine the correct RPM to shift by how much u push on the accelerator. if u floor it it will go into power mode. at the same time it will not go to comfort mode if u go slow.
Dan
Old Sep 28, 2000 | 01:47 PM
James92SE's Avatar
2 VE's are better than one!
yeah i cant tell a difference either, so mine just stays in the middle.
Old Sep 28, 2000 | 03:55 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: switch
PJ
actually...my gas mileage has improved since using power mode and leaving OD off....i drive in a city/suburban atmosphere so speeds are relatively below 50mph most of the time...less gas is need since the car responds quicker...i dunno why but i think Matt93GXE can explain it the best...
Old Oct 5, 2000 | 07:48 PM
Re: Re: switch
PJ
I couldn't tell ya why....Just makes sense that higher rpms shoot more gas is used. And on mine if I keep it in power I get much worse gas mileage. Maybe you don't revv that hard in first place? are you easy driver? Also, if you are under 50 mph most of the time then it wont matter much cuz OD won't matter until higher speeds (never noticed exactly what speed it goes into 4th though)
PJ
Old Oct 6, 2000 | 12:26 PM
DigitalDashMax's Avatar
Thanks,
Roman
[/QUOTE]
Do you have the Sonar Suspension as well as the power transmission?
Ryan.
Old Oct 6, 2000 | 12:53 PM
Bryan91SE's Avatar
I can easily tell the difference between the modes. I normally drive in the normal position, but will put it in power once in awhile. It seems that in normal, I can pretty much dictate with the accelerator when I want it to shift. The Max auto tranny "listens" to me well.
Old Oct 7, 2000 | 09:32 PM
Don19
****in around with my friends i threw it into power and floored it and bam i blew my transmission. It would start up nice rev nice just not go anywhere. That cost alot of money to fix now that switch doesn't even work(thats prob a good thing).Later.
Don
Old Oct 8, 2000 | 11:50 AM
chris92gxe's Avatar
Well I dont even bother with the switches anymore. When I want to pass or race I just shift it manually. This seems to be the fastest wat to shift then I can controll whther or not it shifts at redline or not. My friends think that because of this it is why I have had my tranny rebuilt 5 differnt times but I cant see whay shifting manually would hurt your tranny. I just think the first one I had in it was weak. The one I have now seems to be doing just fine.
Old Oct 9, 2000 | 01:36 PM
roman's Avatar
What is a sonar suspension?
What is the "Sonar Suspension"?
Thanks,
Roman
Ryan.
[/QUOTE]
Old Oct 9, 2000 | 01:50 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: What is a sonar suspension?
Thanks,
Roman
Ryan.
[/QUOTE]
option that came with the car. supposely there's a sensor that reads the rd and adjusts the firmness of the struts. the car also came with summer tires (non all season) and i think ABS.
but that's in 91..
Dan
Old Oct 10, 2000 | 07:45 AM
I am begining to think from all of the threads that no one in the U.S. has seen a Nissan Maxima like mine. Well hears a description of my Max. Its a 1991 Nissan Maxima (obviously) "Brougham" Edition. I have the standard SOHC engine. with automatic climate control. Now here's the different part. I also have a full electronic dash with a heads up display which displays my speed on the widshield. Also you know next to your A/T switch you have a coin holder on my Max it has a button that controls the sonar Suspension. Sonar suspension a sonar unit in the front and the back of the nissan maxima the sonar unit takes a reading as to the conditions of the road (bumpy, flat, wet, etc...) and the speed that I am going at and automaticaly adjusts the suspension to suit those conditions (either Firm, Normal, or Soft). Something also different about my car is that being a Canadian car I don't have the automatic seat belt that the U.S. cars have. If you know of anyone else that has a Max like this please let me know who.
Ryan.
Old Oct 10, 2000 | 08:01 AM
max95q's Avatar
damn your car is tight
They made heads up display for cars back then. I never new. Man I like your car. How much was your brougham edition?
Old Oct 10, 2000 | 02:22 PM
My Car cost me $7500.00 Canadian In Febuary of 2000. It had 141,000 Km's on it.
Old Oct 11, 2000 | 11:41 AM
Bryan91SE's Avatar
Manually downshifting an automatic transmission is bad. I heard that firsthand from the mechanic who rebuilt my white Max's transmission.
Old Oct 11, 2000 | 12:12 PM
roman's Avatar
What does it mean to manually downshift an automatic?
I have an auto and I know that I can control when it downshifts by depressing the gas pedal at a certain moment. Is that what you guys are talking about?
Why is that bad?
Roman
Old Oct 11, 2000 | 12:19 PM
Bryan91SE's Avatar
Re: What does it mean to manually downshift an automatic?
It means to take the lever and manually move it to the gear you want it to be in.
Old Oct 11, 2000 | 12:43 PM
chris92gxe's Avatar
So is just downshifting bad? is it a problem to always start in first and shift it manually instead of driving around in D all the time. I wish I didn't have my crappy auto.
Old Oct 11, 2000 | 01:40 PM
Bryan91SE's Avatar
Upshifting he said was okay. It's bad when you downshift while the car is in motion. Like downshifting to 1st when going 25 mph. I upshift all of the time.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
REDinLV
Sep 28, 2015 12:31 AM
