Fuel Warning Light
Old Nov 6, 2004 | 11:28 AM
Tin's Avatar
Tin
Fuel Warning Light
when is the light set to come on at? as in how many gallons do u have left?
Old Nov 6, 2004 | 11:40 AM
dkris42's Avatar
lol i havew more gallons left when the light comes on then i do my first 1/4 tank
Old Nov 6, 2004 | 11:55 AM
Mizeree_X's Avatar
Getting back to his roots
I think the general consensus is that you have 2-3 gallons left when the light comes on.
Old Nov 6, 2004 | 12:13 PM
Tin's Avatar
Tin
wow i didnt kno it was that much...
Old Nov 6, 2004 | 12:16 PM
Cliff Clavin's Avatar
Way out West
You don't want to push it. I think in my first Maxima I went about 70 miles (on the freeway) with the fuel light on and it didn't run out of gas. I was pretty scared, though. I was trying to make it through an area of super high gas prices and I was low on money. Looking back, I really should have stopped and put in a few bucks worth.
I am not suggesting you try to see how far you can go, I am just telling of my own personal experience.
Old Nov 6, 2004 | 12:51 PM
DMad8724's Avatar
2 3/8 gallons i think is what the chiltons or hiltons manual
Old Nov 6, 2004 | 01:21 PM
DennisMik's Avatar
When my light comes on, I need 15 gallons to fill. Is the tank capacity 18 1/2 gallons?
Old Nov 6, 2004 | 01:46 PM
nismobaron's Avatar
Depends on what you mean by "fill". If you wait until the gas stops pumping, that's "full". If you keep pumping gas until it almost overflows, that's "overfull" - which is bad, as then the gas system cannot "breathe" properly.
The gas tank is 70 liters or approx 18.5 US gallons (15.5 Imperial gallons). That's for the tank alone - the filler tube is not included, but without measuring it, is approx 1-2 gallons. The gas light is going to come on with around 2-4 gallons left in the tank.
BIG NOTE: For fuel injected engines, you are advised against constantly running very low or completely out of gas, as the sediment will seriously damage the fuel pump. However, in these times of high & fluctuating gas prices (thank BS-Bush for that one...), am guessing most of us drive until we're almost empty.
NB: to any Replubican voters who feel offended, will apologize now.
Old Nov 6, 2004 | 06:27 PM
internetautomar's Avatar
mod or sell?
when mine comes on, Wait mine doesn't come on!
and the low fuel issue is not so much sediment in the tank as it is overheating the pump. the dasoline acts as coolant when the pump is submerged.
Old Nov 6, 2004 | 10:30 PM
nismobaron's Avatar
Oh yeah, I knew there was another reason for not allowing fuel to get low!
Old Nov 7, 2004 | 11:35 AM
subs1000w's Avatar
i know the max is sopose to have an 18gallon tank but i ran out of gas once. walked to the gas station bought a 1gallon container put that in then drove about a 1/4mile to the gas station and filled it up and it only took 16 gallons so im not sure why i would run out with at least 1 gallon still in the tank
my gas light doesnt work either so i just fill it up when im at the bottom of the last mark and it ussually takes 15 to 16 gallons
the most ive ever fit without running out of gas is 16.5 gallons and that was at a gas station on a slight hill
Old Nov 8, 2004 | 11:52 AM
teamue's Avatar
I need this answer ten days ago when I ran out. How many miles (average) should you get per gallon?
Old Nov 8, 2004 | 01:55 PM
longpole938's Avatar
currently in MN im getting 19 around town and i just took a road trip averaging about 95mph and got 25mpg (and thats why a 126mph for a couple minutes with 4 people and lugage... i know its dumb ta do so you can save your breath, i dont do that usually i just wanted to get to where i was going)
Old Nov 8, 2004 | 08:24 PM
nismobaron's Avatar
I've been tracking my fuel cunsumption for a while and with a mixture of city / highway driving, average 21.63 miles / US gallon or 25.98 miles / Imp gallon (in metric that's 9.2 liters / 100 kilometers).
I have managed 30 US mpg on a long distance drive, though.
Old Nov 8, 2004 | 09:46 PM
Minty91GXE's Avatar
i'ms told that the air in the tank can cause corrosion, particularly in humid areas.
Old Nov 9, 2004 | 01:23 AM
nismobaron's Avatar
You may get corrosion in the gas tank provided: 1) you don't use your car for many months / years and 2) you leave the gas cap off.
Because you're constantly filling & draining the tank, and because even humid air doesn't really "sweat" in the gas tank, you're very unlikely to have water droplets attach to the metal surfaces long enough for there to be a corrosion issue.
Your gas tank is more likely to rust from the outside in, especially if the undersealant is damaged and dirt builds up.
Old Nov 9, 2004 | 08:14 AM
95turbo gxe's Avatar
I have drove over 60 miles on my gas light before. I was in the middle of no ware in TN and the light came on and I knew that I could go 40miles on it but then still no gas station and I push it to 62 miles before I got to one.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
