vg compression after boost and running rich
Well I did a compression check on the motor before I went with boost.And I have put about 500 miles on their with 7psi boostboosty queit regularly. I shift at around 4500 rmps under boost Because im running factory everthing! My plugs seem to indecate that im running rich How could this be with factory fuel pressure and only 180cc injectors. But this is how the check came out
1 180 psi
3 177
5 180
2 177
4 172
6 177
Standered is 172psi with a max diffrance of 14psi per cylender
So I take it my motor is still in good shape
It has 169,000 on it
1 180 psi
3 177
5 180
2 177
4 172
6 177
well this is the old set up not hook up in my sig. But I have took new pics just havent downloaded them in to my mother cpu yet. But as soon as i get a chance I will she lives and hour a way as Im on a public computer now as mine has some issues
if you're running rich there's a possibility that you're leaking boost out of your intake. i've blown a few holes in some couplers and when that happens, under boost, it runs rich due to metered air being blown out of the intake an not into the engine. you might double check your piping to make sure that's not the case.
t6378tp
09-29-2018 04:27 PM
JoshG
51
09-21-2015 10:41 PM
ballerchris510
09-10-2015 09:35 PM
