removing engine
removing engine
just wondering what is the easiest way to remove our engine from our maxes...would it be easier to drop it through the bottom or pull it through the top?? thanks in advance
will
will
Originally Posted by alpicone
Do you have access to a lift?
If you have access to a lift then the easiest way is to drop if from the bottom. Drop it with the tranny an engine together and then seperate them once you have it out of the car. easier that was.
When I swapped my engine I didnt have acces to alift so I had to take it out from the top. It wasn't that hard just it was a little tight. Plus you have to move mor stuff out of the wasy when taking it from on top. I took out the tranny and engine together.
Originally Posted by white90se
i figured that would be the easiest way going out of the bottom...i don't have anything on top of the engine...it's just the bottom end...i took the heads, intake plenum and all of that stuff off...but im most likely gonna go out the bottom...do you think it would be easier to put the other engine in through the top or bottom
yeah..i have access to a lift...engine hoist...whatever i need...i'm goin to school for automotive technology...so i have access to whatever tools i need...i'm tryin to make my engine swap go as quick as possible since i took the heads off my engine to replace the valves...since i thought my timing belt broke...but i found out that the idler or tensioner pulley broke off...so i'm taking the engine out and replacing it with the engine from my other max
and yes bottom on both.
Originally Posted by DanNY
if you're going to school would it be better to ask the teacher or maybe figure it out from your own experience and know how?
will
Originally Posted by Drivin Maxima
would you mind if i asked what school you go to cause i am also goin to school for automotive and im in the central pa area and am looking to do the same thing next year. and it would be cool to know somebody up here who has done it and that i could maybe see in person and talk to about it.
will
Mar 12, 2020 12:06 AM
CAN-Toronto FS: E-Manage Ultimate and patch cable
knight_yyz
Oct 24, 2015 08:05 AM
