power steering hose repl
Old Nov 12, 2004 | 01:54 PM
eddyb2600's Avatar
has anyone sucessfully replaced their p/s pressure hose by utilizing the
existing fittings and crimping new hose to them:
Nissan's price is outrageous>
Ed J
Old Nov 12, 2004 | 03:34 PM
DennisMik's Avatar
bite the bullet and buy a new one. don't try to repair it.
Old Nov 12, 2004 | 04:45 PM
Greeny's Avatar
¯\(°_o)/¯
Do you have gxe or se?
Old Nov 12, 2004 | 04:55 PM
eddyb2600's Avatar
just located a used one at the local wrecking yard - $25
will install the used one for now and experiment with the leaker
93 GXE auto trans - just purchased from the orig owner with 122,00
Ed J
Old Nov 12, 2004 | 04:57 PM
Greeny's Avatar
¯\(°_o)/¯
Brand new hose...$10 more.... http://www.autozone.com/servlet/UiBr...OSE&PageSync=5
Old Nov 12, 2004 | 05:14 PM
eddyb2600's Avatar
nissan # 49720-86E02 quoted $175 at local dealer (calif)
Ed J
Old Nov 12, 2004 | 05:29 PM
Greeny's Avatar
¯\(°_o)/¯
Don't pay the stealership prices.
Old Nov 13, 2004 | 11:32 AM
Bman's Avatar
Beck/Arnley sells a hose... just start calling up parts stores. MUCH cheaper than a dealership part and you don't want to use a junkyard piece because you might have to go through this mess again at any time.
Old Nov 13, 2004 | 01:50 PM
DennisMik's Avatar
Beck/arnley hose $39.79 at rockauto.com.
Edelmann hose 34.79.
Old Nov 13, 2004 | 02:59 PM
aminus21's Avatar
I bought my Gates for $40 w/lifetime warranty
Old Nov 13, 2004 | 05:04 PM
internetautomar's Avatar
mod or sell?
oh yeah, I gotta redo those prices
Old Nov 16, 2004 | 01:36 PM
eddyb2600's Avatar
completed the repair Sunday - the hose as supplied by AutoZone does NOT
fit. ain't close - one end as supplied by them had a 90 degree bend about
7-8" long.
replacing the hose from the pump to the block fitting behind the strut
tower that has an electrical pressure switch.
Ed J
Old Nov 16, 2004 | 01:47 PM
mod or sell?
there are 2 options, and you can't tell which one you have until you've gotten a good look at the hose.
Old Nov 16, 2004 | 05:51 PM
mike92's Avatar
Hi, I have replaced the hose yesterday. I got it from NAPA auto parts for about 50 dollars. The hose with the 90 degree bent is for models with electronic control solenoid on the pump body, which is not my case. The hose fits perfectly and it looks good quality, furthermore it has an aluminum protector to keep it safe from the engine’s heat.
Old Nov 16, 2004 | 05:58 PM
Greeny's Avatar
¯\(°_o)/¯
[QUOTE=eddyb2600]completed the repair Sunday - the hose as supplied by AutoZone does NOT
7-8" long.
I bet they gave you the one for the gxe model.
Old Nov 16, 2004 | 06:16 PM
Greeny's Avatar
¯\(°_o)/¯
The autozone gxe part # is 71445........se part #80100....Also the se model hose is special order only.
Old Nov 16, 2004 | 08:24 PM
aminus21's Avatar
Same thing happend to me when I replaced my pressure hose. I have a GXE, and the GXE hose did not fit, I took my old hose back to the parts store (not autozone), and they said that I had an SE hose.
Is there a difference in power steering pumps in VG engines??? whats this electronic control stuff???
Old Nov 16, 2004 | 09:52 PM
Harvs94max's Avatar
replaced mine on my se 34 bucks advanceautoparts lifetime warrenty
Old Nov 17, 2004 | 06:06 AM
Greeny's Avatar
¯\(°_o)/¯
Is there a difference in power steering pumps in VG engines??? whats this electronic control stuff???[/QUOTE]
The "electronic control stuff " is a device that raises or lowers the amount of power steering needed according to your speed. In other words if you are going thru the store parking lot at 5mph it gives you full power steering. But on the highway at 60mph you do not need as much. It gives you a much better feel of the road......
Old Nov 17, 2004 | 06:10 AM
Greeny's Avatar
¯\(°_o)/¯
I think its called "variable power steering"
Old Nov 17, 2004 | 06:11 AM
90maroon15.1's Avatar
the exact same thing happed to me.. im using an SE hose right now
Old Nov 17, 2004 | 06:12 AM
it is speed sensitive power steering
lowpost99
Oct 26, 2025 06:53 PM
conansriver
Nov 18, 2015 02:46 PM
followthadollar
Sep 13, 2015 09:55 AM
SusieQQ
Sep 9, 2015 12:14 PM
