subwoofer problems
Old Nov 15, 2004 | 01:34 PM
4thgradedropout's Avatar
subwoofer problems
ok so since my original amp fried i had an 80 watt amp for my 575 watt 12 inch sub but i just revieved a hand me down kiker amp that is around 500 watts but i installed it and it sounds the same if not worse so im not sure what the problem is...any ideas? my dad said it was not grounded right but i have the same ground as ive always used wich is the bolt that ataches my seet to the frame
Old Nov 15, 2004 | 01:43 PM
swowlinc's Avatar
1993 SE
You need to find out what impedance the sub is wired at. Amps put out different power levels at different ohms loads. I use the same ground so it's good. What kind of sub is it? what amp model?
Old Nov 15, 2004 | 01:49 PM
it is a pioneer sub and a kiker amp but im not sure the model all i know is it is old
Old Nov 15, 2004 | 01:52 PM
swowlinc's Avatar
1993 SE
It should tell you the model number on the amp somewhere.
Old Nov 15, 2004 | 01:57 PM
Kikcaffine's Avatar
make sure the settings are correct
Old Nov 15, 2004 | 02:01 PM
DMad8724's Avatar
are you using the same wiring? the new amp could need thicker gauge wiring..
Old Nov 15, 2004 | 02:13 PM
tobe2be's Avatar
single voice coil sub or dual? make sure the filter on the amp is set to low not nuetral or high. make sure that your taking juice from the correct chanel. if all else fails then that amps isnt that good.
Old Nov 15, 2004 | 02:19 PM
well the amp only has one setting on it and it is a gain *** other than that i have 4 gauge wireing wich i thought to be big enough and i know the amp works cause my brother just unpluged it from his mustang where it worked pretty damn good i might say.
Old Nov 15, 2004 | 05:38 PM
AscendantMax's Avatar
we have a forum dedicated for audio related questions/threads...
but anyways, 4 gauge wiring should be fine for your amp. that's might not be the issue. if you used the same grounding point and it worked before, then you can eliminate that as a problem (considering it's making good contact with the chassis). i would check your gains...
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
