Help a Gross Polluter
Old Nov 19, 2004 | 04:33 PM
cardshark's Avatar
So I moved to Cali and took the smog test - failed the ignition timing. I scored a 905 when the max allowed is 724. It turns out my radiator fans are always on. Even when the car's cold they turn on, seemingly screwing with my idle. Strange I never noticed this. The mechanic says he has no ideas and it'll take a couple hours to diagnose. ECU has no codes, could it be bad? Or is it just a relay? It's an auto vg. Any ideas?
Old Nov 19, 2004 | 05:03 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
if the fans are on all the time then the temp sensor may have gone bad. when the engine reaches the preset temp the sensor clicks in the relays thus firing up the fans...or the relays are frozen.....just check with a meter....
Old Nov 20, 2004 | 03:51 PM
internetautomar's Avatar
mod or sell?
install an aftermarket fan switch, set it to go on at about 170
dcam0326
Sep 7, 2015 07:26 AM
wan2bfast4vr
Oct 23, 2003 06:31 AM
Dstyle
Dec 30, 2002 02:22 PM
