just bought 4th gen seats
Originally Posted by shavedmax
you go boy!back to the subject at hand........welcome to the 4th gen seating crowd. i would never go back the crap seats i had before, even the pillow top ones on my 93 feel worn out. i welded my brackets in place. make sure you are dooing the right thing safety wise. 200 lbs going 20 mph can do alot to a wimpy screwed on bracket. be safe
ill tell you what though the only pain in the butt was leveling the seats when i first put them in they sat very crooked, LOL
Originally Posted by icepick
where did this direct bolt on crap come form
bween my seats is a console i had built(took it out) and my skull switch box for my HYDRAULICS.
i think i had taken some but dont have them anymore, i modified the front to bolt onto the seat crossmember, welded some grade 8 nuts to it and that was that for the front. i think one of the factory rear mount points worked too, but the side by the tranny hump i welded a grade 8 nut to the sheetmetal and i think the brace from the seat is right up against that. make sure you use grade 8 stuff like they do from the factory so it doesnt fall appart
when i get time ill take pics the rear has a "u" bracket that is welded to the tranny hump then bolted to the seat. the other side is factory location just a longer bolt with a few nuts and washers to level it out. thats for the rear. the front needed a new hole only on one side the other just drilled in. so for the drilled side i got under the car welded the nut in place and just bolted her down so it looked as factory as possible.
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
