howdy
Old Nov 23, 2004 | 09:20 AM
aznman007's Avatar
howdy
whas good yall? well i signed up in january but never really posted because the 1990 Maxima aint mine. it soon will be though. so here's the thing
this car has been sittin for 8 months, and time to time it'll be started just to keep the fluids runnin through the car. it has a tranny leak problem somewhere, power steering leakin, and oil is leakin burnin from somewhere.
with all these things, what else do i need to do to get her runnin right again after all this time of sittin?
oh yea it's a GXE, not the SE.
Old Nov 23, 2004 | 11:15 AM
Scope's Avatar
Im izz sexay
Once you get those fixed the VG doesn't has any other real issues engine wise atleast.
Old Nov 23, 2004 | 12:26 PM
Cliff Clavin's Avatar
Way out West
The "oil is leakin[g] burnin[g] from somewhere" doesn't really make sense. Is it leaking oil, burning oil (black smoke out the exhaust) or is it leaking oil on top of something like the exhaust manifold, where it smells like oil is burning?
Old Nov 23, 2004 | 01:18 PM
aznman007's Avatar
ah, the leak is comin from on top of the engine. i think where the red valve cover meets the engine. im thinkin it's gasket. also have any of u ever left a car on hiatus for a while and when u started it up again it ran fine?
Old Nov 23, 2004 | 01:57 PM
AscendantMax's Avatar
make sure those screws/bolts holding the valve cover is on tight. several of mine came loose (Guessing over time) and oil slowly leaked out.
Old Nov 23, 2004 | 02:04 PM
nubiannupe's Avatar
OG Maxima.org Member
Heck... while you're under there, why don't you just REPLACE the gasket. With your car pushing 15, it's a safe bet that the underside of your valve covers haven't seen the light of day since it rolled out from the assembly line.
Food for thought... do the dishes!
Old Nov 23, 2004 | 03:33 PM
95turbo gxe's Avatar
yeah he is right you may want to check and see if thier tight do not overpower them just snug them.
Old Nov 23, 2004 | 03:37 PM
aznman007's Avatar
thanka much. what about brakes? they seem a lil weak and i have to push thema lil more than i used to. better yet can anyone post a list of things to do? it has 186000 miles on it and im not sure where to start since it's not my car in the first place.
Old Nov 23, 2004 | 04:34 PM
ChrisCheezer's Avatar
-The car was sitting for 8 months! with out being started??
-I hope there was oil being sprayed in each cyl, during that time, and you let it prime before you started it..
-as for the brakes, you might have to drain all the fluid, and ill it back up, seems like there's moisture in the fluid making the pedal feel like crud, or maybe the pads/rotors are simply worn down, rotors flake off and turn to crap when their sitting outside, in the weather for long periods of time...
do a FULL TUNE-UP, drain and fill everything fluid, I would use a good engine/tranny stop leak, some of them do work.
Old Nov 24, 2004 | 04:02 AM
NYmax91's Avatar
my car sat for close to 6 months with out getting started more then 4 times and the last time it i whent to start it she was tottaly fine. still is tottaly fine. she's got her old age quircks but whatever. http://members.cardomain.com/nymax91
Old Nov 24, 2004 | 07:33 AM
wow.. crazy lighting in thoes few first pics,
-that red maxima is soooo nice, but i bet the driver is
altmycar
Aug 6, 2015 04:44 PM
SKY
Oct 16, 2004 05:26 AM
2k2-blk-6spd
Nitrous
Sep 14, 2004 09:10 AM
yongjun
Jul 8, 2001 06:46 AM
